MilenniumExplorer
- November 16, 2020
- NC
- 2000 Explorer XLS
Hey all. I've been chasing this particular noise for some time now and I'm kind of at a loss now.
My 2000 XLS, with the OHV, has been making a high-pitched rotational squeal (more of a scream really) that starts out as a mechanical type growl, and increases in pitch as I speed up, when moving. Looking through the threads here, I saw some saying it could be a wheel bearing going out, others saying it could be a camshaft position sensor or a valve on the firewall. Since it only happens when I'm driving, it must be something in the axles, right?
In the time my truck has made this noise, the front wheel bearing on the driver's side actually did go out. So I had it fixed this week, and the noise seems quieter but is still there. Additionally I had the front driver's ball joint and tie rod (which I know won't make rotational noises) replaced. So what else can it be? The sound is difficult to place while moving but still seems to come from my left side, so is it possibly just the rear bearing? I've got a very slow rear diff leak which I plan on fixing soon, could it be that instead?
It still feels most likely to simply be the rear bearing, but I just wonder if there isn't anything else that could be causing this.
