SunSearching
- May 3, 2006
- Athens, GA
- 2000 4x4, 96 BMW 328is
ok before I start, I admit that I postponed fixing a problem and now it is probably coming back to bite me in the rear, but so be it... I need help figuring this out.
The truck: 97 XLT, 4 wheel disc, ABS
The pre-problem: scrubbing from the driver's side rear brake. Sounded like a mildly seized caliper had the pad rubbing the rotor. Good bit of heat coming off of it, too lazy to fix immediately.
The current problem: Brake fluid is leaking out and I cannot find where it is coming from. I had my dad sit in the truck and pump the pedal, and there was fluid oozing out, but I couldn't quite make out exactly where it was coming from. Regardless, there is DEFINITELY a leak, on the same wheel that the scrubbing noise was coming from. Oh yeah, now that the fluid's leaking it doesn't make that noise anymore, which furthers my theory about it being a caliper issue.
The question: My theory is that the high heat coming off the brake caused something to loosen, melt, or in some other way deform itself enough that the fluid is now just leaking out. Any ideas where this is most likely to happen? The truck is now officially grounded until Monday when I have time to pull the wheel off and replace some stuff, but I would like to not have to pull the entire thing apart if I can avoid it. So, if anyone has been in this same boat before, please let me know a good place to start looking.. as I said, I can't really narrow it down to a specific location for the leak... there's just kinda brake fluid all over the place, which sucks a lot.
