ejkob
- August 15, 2008
- St. Charles, MO
- 2000 Ford Explorer Sport
I have searched for an answer to this problem and find bits and pieces. I just purchased a 2008 EB Explorer and once I got it home found out that the vanity lights, the map lights and homelink does not work. The only time the map lights work is when to door is open, or if I move the dimmer switch to the on position. I did have a broken vanity light but have since replaced it. I have not traced any wiring yet but am wondering how to know if FORD has to reset the system for the lights to work again. The smart junction box seems to be ok and when I pull the fuse to check the system, you can hear a relay operate when the fuse is put back in. Is there a wiring diagram that I can get ahold of to check the wiring? Any help is appreciated.
Thanks
Thanks
