Horn location
MikeHTally
Location
N. Florida
Tallahassee
2020 Explorer Limited
Where is the horn on the '20 Explorer? I'm guessing it's under the trim piece between the radiator and the grille. I want to add an air horn. I bought it for my '19 Escape, but never installed it.
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
That is where it was located on the 5th gen. I believe it is in a different location on the 6th gen, But where, I don't know. Perhaps you can isolate the area by sounding it.
peterk9
Staff member
Moderator
Callsign
VE3
Just found this Mike. Let us know if that info is correct. Thanks.
Locate the horns by sliding under the front of your SUV. The Ford Explorer has high and low tone horns that are both under the driver's side headlight behind the front bumper.
MikeHTally
Location
N. Florida
Tallahassee
Yeah, delaying that as long as possible. I just need to tap into the switch lead to trigger a relay for the air horn. Is there a wiring schematic out there somewhere showing the color of the wire?
MikeHTally
Location
N. Florida
Tallahassee
Thanks. I looked in the cavity below the headlight. Nothing obvious. When it cools off, I get under it and go exploring. Funny, the Mazda was a cinch to do. I never did find a way to mount the horn on the Escape. There are lotsa options to mount the horn on the Explorer, but it'll take a while to locate the + lead for the horns and tap into it correctly.
I did see what looks for all the world like a hard drive directly under the headlight. Probably the transformer for the assembly.
MikeHTally
Location
N. Florida
Tallahassee
Found 'em (I think). Reaching WAY down through a gap in the frame, I can touch what feels like a car horn. 20% further along than I was this morning. Thanks! Looks like there are bunches of screws holding the bottom splash shield.
MikeHTally
Location
N. Florida
Tallahassee
Finally found it (I think). I found a diagram that was not every Explorer built since Noah built the Ark. The diagram (from Ford) shows them on the passenger side, just outboard of the grill and radiator. I reached way down with a flash light. I think I see the back side of the horns and the mounting bolt. Now, getting to it still seems problematic. Does anyone know what color wire supplies voltage when the horn button is pressed?
