Horn sound off / on by setting in Forscan | Ford Explorer - Ford Ranger Forums - Serious Explorations
SanSebek
Brzeg
2015 PIU
Hi all,
Has anyone seen in Forscan with the option to turn off or turn on the horn?
In my PIU'15 vehicle the horn worked (I also checked the fuse no. 22 - it's ok) before I changed a few settings in the BCM, which did not directly concern the activation / deactivation of the horn (I think so;)
Now I try to figure it out and nothing comes to my mind anymore.
I found this information, but for the Ford F-150 (2015-2020 Ford F-150 Forscan decoding)
SanSebek
Brzeg
2015 PIU
Did you ever figure this out?
Hi,
yes, these settings in forscan (which I wrote above) will not change anything in my PIU,/ as you can see from F150/.
The reason was a damaged cord. After replacement, the horn works;)
