Eki
- October 8, 2005
- Uusimaa, Finland
- '96 XLT
As gijoecam (-Joe) wrote at 09-15-2005:
Wheels and Hubs, Explorer
The Dana 35 IFS axle used on the Explorer utilizes a disconnect mounted on the axle housing. The disconnect consists of a shift motor which operates a shift fork and locking collar, an indicator switch which operates the 4WD light on the instrument panel, a vacuum switch and a vacuum harness.
When the 4WD mode is selected, a signal is sent to the generic electronic module (GEM) which energizes an electronic valve located in the right front cowl that draws a vacuum on the disconnect shift motor.
The 4WD locking collar on the transfer case engages the front driveshaft. During this time there will be a 3- to 4-second delay while the inner shaft comes up to speed. The vacuum that is drawn on the disconnect motor moves the shift fork located inside the disconnect housing against a locking collar and slides it between the inner shaft and the constant shaft which locks them together and puts the vehicle into 4WD.
To disengage the transfer case, select the 2WD switch position. This will unlock the transfer case and reverse the direction that the shift motor moves the fork which slides the locking collar from between the inner and constant shafts and disengages them.
The four-wheel drive has two modes: low and auto. Low mode is used to increase torque for extra pulling power. The auto mode senses a slip condition and automatically engages 4WD similar to the Aerostar by distributing torque between the axles.
Still I'm stupid enough not to understand how 4wd low should work. And yes I have a problem.
I have '96 4.0 XLT, 5R55E, t-case is 4405 (I guess)
When I take battery cable off to reset the system. Always after reset when I first time switch to 4WD Auto while moving (on the fly) it will not engage, both lights start flashing after a while. If I switch to 4WD Auto when I'm not moving (once is enough) then she will engage always on the fly.
- while ignition is on (engine is not running) when I switch on 4WD Auto I can hear vacuum hiss and 4WD light on the instrument panel goes on.
- When the gear is in Neutral and I switch 4WD Low, I can hear it actually shift. 4WD Low light goes on.
All seems to work OK, but according to road test it's not working. Proper testing (other than low range=low speed) is difficult since we don't have snow in Finland (yet). Sooner or later it will snow, it allways does, believe me Yes I could go an try on mud field, but I hate the idea leaving my Ex there
So far what I thought about 4WD Low:
- Transfer case should share 50/50 torque to rear and front, no diff?
- driving on 4WD low she would rather go straight than doing 360 circles?
Could it be:
Low mode is used to increase torque for extra pulling power. Low mode also senses a slip condition and automatically engages 4WD?
Is there any easy way to test 4WD?
20 years ago I had '72 Range Rover. Comparing my EX to Range I think everything isn't right.
best regards
-Eki
Could it be:
best regards
-Eki
