how can i tell if i have a stock limited slip differential
punkbek3886
Vero Beach, FL
'91 Sport
i was just wondering, i have a 91 explorer sport and i want to know if the original owner got the limited slip differential that was offered as an option from the factory. how can i test for this?
Yomie
Biloxi, MS
06 Toyota
Look in the Door Jam at the white sticker, look for the Axle code and post it here, from that information we will be able to tell you if your vehicle came with a stock limited slip diff
Retard
San Jose, CA
98 Ranger
Or on the pumpkin it will tell you which rear-end you have as well as the gear ratio and wether or not its limited slip, might have some other stuff too I dont really remember, but its something like this (roughly)
8 8 3 73L
Meaning an 8.8 /w 3.73 and limited slip.
Mbrooks420
High Voltage.
EF Vendor
1998 Mountaineer AWD
D4 is the l/s axle code
Robert
Location
CA
Kelseyville, CA
'13 Ram 1500 Longhorn
Only for a 3.73 limited slip. Ford also offered a 4.10 limited slip (D2) although I don't think so in '91, a 3.27 limited slip and a 3.55 limited slip.
Mbrooks420
High Voltage.
EF Vendor
Opps, I thought there was only the 3.73, until later years.
punkbek3886
Vero Beach, FL
'91 Sport
the axle code is d4! that is awesome! how good is the factory l/s diff anyway?
punkbek3886
Vero Beach, FL
'91 Sport
by the way, does that mean it has l/s both front and rear or just rear?
Mbrooks420
High Voltage.
EF Vendor
It's just the rear, and I really like mine. They do wear out, but the parts to fix it are under $100. The factory l/s works well as long as you are easy on the gas.
zavaral
Furby Murderer
Moore, OK
'91 LMT-XL
i looked on my white sticker in the door and under the axle it said 45 what exactly does that mean
Crankcase
Moderator Emeritus
Moderator Emeritus
Vancouver B.C, Canada
1992 XL Ex-Police
zavaral
Furby Murderer
Moore, OK
'91 LMT-XL
on that thread it said
45 Open 3200 3.55
what does that **open 3200** mean from that i dont have limited slip (damnit) but what does that open 3200 mean
zavaral
Furby Murderer
Moore, OK
'91 LMT-XL
ohhh ok how much would a limited slip 3.75 cost around
punkbek3886
Vero Beach, FL
'91 Sport
so does that mean that there is no traction aiding device in the front? if not, how much would it cost to get one? i can do my own mods, so all i need is the cost of parts.
