Prince_Polaris
- October 6, 2016
- Maryland
- 1998 Ford Explorer Sport
Okay, so this is a simple question, since my explorer is a 98 the plastic is obviously kinda old. However, the vents are hard to mess with because the close/open knobs like to stick, and moving it up/down and left/right is also hard, cause the plastic just wants to stick together so I feel like I'm gonna break it whenever I try adjusting something. Is there something I can use to clean the vents so that they move smoothly again, I was thinking perhaps WD-40 or no? Heh, it's getting nice and cold up here, so I need the heat. And on that note... my blend door is shot, I have air on MAX AC and every other mode pumps out heat, so I have both, but I don't like only being able to choose full heat and I feel like it might wear out my heater if it's always going at 100%, so should I replace the blend door thing (actuator?) or won't it just eventually break again?
Also, this is probably a common issue I could look up but I figured I could ask anyway, my wonderful SOHC is having a few more problems... When I start it up, this is hard to explain, but it just feels like it's really struggling to get going, but the check engine light doesn't come on or anything. It's getting cold up here in western maryland and I haven't had the battery checked, should I go do that? And if I do, where should I go, walmart, autozone, or advance auto parts? Also, it's not idling nice anymore, it will just keep going vrrrrRRRrrrrrrrrrRRRrrrrRRrrrrrrrrrr, but maybe that's related to the timing chain and its rattling.
And lastly, while I am waiting for my silicone lube to be delivered, is it okay to use my window if it has to REALLY struggle to go down? It's okay going up, but it's having a hard time going down about the first half of the way. The passenger window is the same, but not as bad.
