How many miles on your 3RD GEN! orig. tranny????
Kesp4.0
Los Angeles, CA
1993 Explorer XLT
My transmission just passed 160K but the o/d light is flashing, so I think she is finished
jpedi001
Virginia Beach, VA
2004 Ford Explorer XLT2WD
Sitting at 140k right now with only 1 transmission fluid change. no towing or up hill. mostly highway. shifts hard sometimes and will occasionally stall shifting out of reverse.
hopefully I can get a few more years out of it.
TTSaleen
Apex, NC
2003 Explorer XLT
167k miles on my 2004 Eddie Bauer.
I just performed a filter and fluid swap on it at 166k miles.
Appears to be the 1st time it was ever changed (I am the 2nd owner).
Shifts perfect. No issues to date.
chopperb
Chicago
04 explorer
150k swapped solenoids at 142k fluid looked like new
danielhrdy17
Kingwood, WV
2002 Ford Explorer XLT
My 02 xlt has 147,857 and the trans is fine. Doesn't slip and it runs great
Moto Martin
So. Cal
02 xlt 4.6 & 03 xlt 4.0
I do not know why everyone is having so many problems unless it is because they change their fluid.
I don't understand the science/logic behind not changing the transmission fluid, it's a consumable item and gets used up like every other type of oil ever made.
One reason I think that there are some problems is because of the method of checking the transmission oil level - it is not intuitive. If it is checked cold with the motor off it is possible to think it is over filled when in reality if checked warm with the engine running it may be 2-3 quarts low. I'm not sure every mechanic knows this and would lead to problems even though it is stamped onto the transmission pan.
explorerman84
Pine Grove, PA
2005 XLT 4x4
My 05 XLT V6 has 167K miles. Runs Great.
wbrudi28
West Islip, NY
2004 Explorer 4x4 XLT 4.0
got the truck around 59,xxx, apparently the tranny went before i got it. went when i had it since then, probably around 85-90l (reverse went, tranny replaced under ESP)
knock on wood its ok still. installed an aux trans cooler for added protection.
kevbz
2005 Explorer
Original owner, 220,400...never flushed, never changed. Still shifts great. Occasionally (maybe 1 in 1000 shifts from park to reverse) it does not engage unless you give it a bump in the throttle or go back to park and wait a sec and try again.
Explorer0204
Upstate NY
04 Explorer XLT
64700 or so on mine. I don't beat it at all on the road, only hard acceleration if anything and I am very methodical about shifting into reverse and drive.. I always use the parking brake and make sure that those shifts are smooth as possible. That being said, it does clunk a bit into reverse... Not all the time but other than that it is fine. I wish it didn't make any noises or chunks but overall I am one of the fortunate ones. I would love for it to last to 150000 but even 10000 miles will be enough for me.
kevin512
St. Paul, Minneota
195,200 miles on '02 XLT 4.0.
Transmission has never been serviced in any way. Ford recommended a flush at 150K, but on the recommendation of members here, I didn't touch it. For the last ~3 years or so, I've been getting an occasional hard shift, but nothing major. Lots of highway miles and only occasional light towing.
scorpo8972
Mississauga, Ontario
02 Ford Explorer XLT 4x4
My 2002 bought used had the original transmission (reason why I bought it because thats a good sign at the mileage it was at) Currently at 223,300(kilometres not miles) and still running strong, From what I heard these trannys aren't suspossed to change fluid till 250k which is odd. But the fluid still has half life left even though im so close to 250k.
marked man
2002 XLT V8
6-2001 build date and just had the intermediate band fail. 99k on the clock.
I was leaving a slow cruise in 3rd, lever position, and as I tipped in pop. Lost it.
Only had it a couple months so I am displeased.
Time for a rebuild and a Torque Converter. Thinking on a Dirty Dog TC with 3000 rpm stall.
Any good advice?
r
Rubberhead
Fort Mill, SC
'07 E.Bauer & '14 XLT 4WD
247,000 miles on '03 V8 with Tow package. Change the oil every 3,000; I've flushed the transmission and replaced the rear differential fluid every 60k. She still runs and shifts great. Doesn't burn any oil but I have had to change many of the gaskets like the oil pan gasket and oil filter assembly gasket.
Dawgzilla2004
Texas
2004 XLT
Still trucking
2004 with 196,000 original miles without any fluid changes. A lot of city driving but driven pretty easy
Mr. Truckles
North Jersey
2002 Explorer XLT
My '02 XLT is an early build so it didn't have sleeved servo bores like the '03+ models. If I remember it lasted about 120k. I'm at 240k now with an updated one and I haven't encountered any problems even after 3 years of heavy abuse.
Dalmus
Milwaukee, WI
'03 4.0L Flex; 190K Miles
Now sitting at 185,000 miles on the original tranny on my '03 4.0. Just this year I started getting a rough shift into 3rd after the engine warms up.
I also have power problems in overdrive (stutters a bit if I accelerate, but not enough to drop to a lower gear). That could be do due the fact that the plugs and wires haven't been touched since I bought it at 60,000 miles...
Oddly, I've always got pretty decent mileage until this past year (tranmission and/or plugs, I'm sure... Combined HWY and City over 3 years of tracking gives me almost 18mpg.
Sully1
Petoskey, Michigan
2002 Explorer XLT 4.0
my first EX was an early build 02 and at 110,000 the trans went, and then at 125,000 the motor blew to pieces... but my 04 has 220,000 and is all original
fadeds
niagara falls
2004 explorer
6 months ago in a fit of rage i beat on my 04 with 106k. the next day it started slipping from 2nd to 3rd and of course the flashing OD light. I had it rebuilt for 1,200 with a 12k or 12 month warranty. I'll have to control my temper and take a bit more care of her now.
JLindley
North Carolina
'02 Ex XLT, '97 Ex EB
Replaced my original tranny at 165,000 with a jasper transmission. It now has 193,000; 28,000 on my jasper transmission. The jasper transmission shifts much better than my original transmission ever did!!
94Eddie How many miles on original 3rd Gen Tranny? Stock 2002 - 2005 Explorers 81
S 4.6L V8 - Typically how many miles before timing chain replacement? Stock 2002 - 2005 Explorers 17
K How many miles on your 3ND GEN EX? Stock 2002 - 2005 Explorers 17
L How many miles on the timing chains typically 4.0L Stock 2002 - 2005 Explorers 36
C High Mileage 4.6 motors. How many miles do you currently have? Stock 2002 - 2005 Explorers 4
B How many miles with fully synthetic? Stock 2002 - 2005 Explorers 12
1 How many miles before i should do my brakes? What brand to use? Stock 2002 - 2005 Explorers 7
D How many miles from stock tires Stock 2002 - 2005 Explorers 16
B How many miles will an explorer go for? Stock 2002 - 2005 Explorers 108
A To many questions!! Stock 2002 - 2005 Explorers 12
A Oil pooling between heads (and many other issues) Stock 2002 - 2005 Explorers 13
A No Start after many parts replaced... Stock 2002 - 2005 Explorers 4
B How many O2 sensors on a 2002 Explorer XLT? Stock 2002 - 2005 Explorers 1
F How many quarts? Stock 2002 - 2005 Explorers 6
F How many Catalytic Converters Stock 2002 - 2005 Explorers 8
B How many different lift gate struts are there?? Stock 2002 - 2005 Explorers 7
L How many Ampers for the stock alternater? Stock 2002 - 2005 Explorers 4
W Why do I burn up so many transmitions? Stock 2002 - 2005 Explorers 14
C How many K on your explorer and what repairs recently Stock 2002 - 2005 Explorers 19
R How many Camshaft position sensor on 2002 V8? Stock 2002 - 2005 Explorers 2
Exproblems How many heat shield band straps does a 2005 V-6 Catalytic converter have around it? Stock 2002 - 2005 Explorers 0
C Bought a 2004 explorer (DIYing many issues lots of questions) Stock 2002 - 2005 Explorers 9
A 05 Explorer XLt RSC/Advance Trac Many Issues Stock 2002 - 2005 Explorers 4
S IAC Problem: How many RPM's does your vehicle IDLE at? Stock 2002 - 2005 Explorers 32
N How many Quarts ? Stock 2002 - 2005 Explorers 1
P how many bellhousing bolts Stock 2002 - 2005 Explorers 2
C How many different auto transmissions did Ford, Lincoln, Mercury use? Stock 2002 - 2005 Explorers 0
B How many happy 3rd gen owners do we have? Stock 2002 - 2005 Explorers 21
M 2002 4.6L Explorer with rough idle/many codes Stock 2002 - 2005 Explorers 3
L How many Cats on a late model 2004 Explorer 4.0L? Stock 2002 - 2005 Explorers 3
S '02 V6 Explorer with Many Electrical Problems Stock 2002 - 2005 Explorers 21
R how many balance weights on front drive shaft? Stock 2002 - 2005 Explorers 0
R Running Rough. Many CEL Codes Stock 2002 - 2005 Explorers 2
W 2002 XLS too many wheel bearing failures. Stock 2002 - 2005 Explorers 4
Y How many axles does an 02 Explorer have? Stock 2002 - 2005 Explorers 14
A 2003 Explorer need tire(s) How many?? Stock 2002 - 2005 Explorers 2
C Why are there so many rear diff bearing failures on the 2002-up Explorers? Stock 2002 - 2005 Explorers 36
M power steering fluid leak 225,000 Miles Stock 2002 - 2005 Explorers 1
08EddieCA Get what you pay for: front timing guide fail <11K miles Stock 2002 - 2005 Explorers 8
T 05 Explorer engine fail safe mode after driving 5-7 miles Stock 2002 - 2005 Explorers 7
B "05" XLT 230K miles ABS light on but with a kicker!! Stock 2002 - 2005 Explorers 2
H what to service at 185,000 miles ? Stock 2002 - 2005 Explorers 3
H 2004 XLT with original ATF 160,000 miles Stock 2002 - 2005 Explorers 3
M 2005 Explorer 211xxx Miles. left and right low beams wont turn on. Stock 2002 - 2005 Explorers 4
B 05 XLT high 209K miles Stock 2002 - 2005 Explorers 5
J Miles to E keeps changing Stock 2002 - 2005 Explorers 3
C 03 4.0 17x,xxx miles chain went? Stock 2002 - 2005 Explorers 19
M 2003 Limited v8 - Message Center Shows Oil Change Warning After Only 2k Miles Stock 2002 - 2005 Explorers 3
D Looking for a good Transmission guy in Northern California, Sacramento CA+-200 Miles. Stock 2002 - 2005 Explorers 1
C 2002 explorer transmission 170,000 miles Stock 2002 - 2005 Explorers 2
Similar threads
