How much can I tow with this? | Ford Explorer - Ford Ranger Forums - Serious Explorations
Hello -
I have a 2017 Explorer XLT v6 FWD with an appearance package.
I need to be able to tow a boat which requires about 3,000lbs in towing.
Since my Explorer didn't come with a hitch, I was going to purchase the hitch below:
CURT 13100 Class 3 Trailer Hitch
Was wondering if it is that simple and if anyone had any feedback.
Mbrooks420
High Voltage.
1998 Mountaineer AWD
With no factory tow package your truck is rated to 2,000 pounds, regardless of what hitch you put on it. Can you tow more than 2,000? Probably. I’d surely get a huge transmission cooler, stay out of overdrive and not push it. How far will you be towing? How often?
dseg42
FL
2017 Ford Explorer XLT
I will be towing a few miles every other week. I live in FL, so there aren't any steep hills or mountains. Maybe just the board ramp.
Is there a recommended place to buy transmission coolers and are they easy to install?
Wondering if I should take it Ford for the tow package and pay the ridiculous amount or just purchase the hitch and a cooler.
Mbrooks420
High Voltage.
It would cost many thousands of dollars to have the tow package installed. As I understand it the transmissions are different models. Transmission coolers can be bought at any auto store as universals. They are fairly easy to install. I’d check and see if you currently have one. If so I’d add another inline with it.
If it’s fairly flat, and not a long distance I’d tow 3,000 without too much worry. Don’t rush it, and you probably won’t overtax it.
