syn-
- July 27, 2006
- orlando, fl
- 96 xlt - wip
So after receiving great info from all the members here, I have decided to give back to the community. I will add pictures from various other help threads for identification purposes (once I get permission). Though in short what this write-up will offer is a newer gauge cluster found in (97-0?) sohc explorers and 01-03 sport trac clusters into 96-95 (not sure but this might work for the 94-92) years as well.
Disclaimer:
I am not responsible for any/all damage that you inflict on your fingers, new cluster, or old cluster.
Thanks go to:
ncranchero
1998Exploder
Dan Whitaker
Tools Needed:
8mm
7mm
6mm
Fork
Large Paper Clip
Total Time: 2-3hrs depending on pace
Follow the steps 1-16 mentioned in other sticky:
Dead Link Removed
Questions you need to ask yourself:
1. Do I want my Fuel Gauge to read passed Full?
2. Do I want my Engine Temp gauge to work?
3. Do I want all my Indicators to work?
Answers:
Read this forum for optimum exact replacement needs.
http://www.explorerforum.com/forums/showthread.php?t=203189&highlight=sport+cluster
Note: Skip to the 5th picture and you can see how to detach the fuel and temp readout face plate.
Getting the Temp Gauge to work:
1. You must do this on both Sport and 9x. A Fork is great leverage tool to take off the needles. They don't come off easy, I suggest pulling straight and not wiggling!
2. After the needles are off, remove the temp motor screws from behind each of the face plates.
3. You must use the screws for the Sport they are a Torx bit head (sorry forgot what size might be a 20).
4. Mount and Screw down.
5. Put Face Plate back on Sport housing.
6. Put the Fuel Needle on as accurate as you can the computer will adjust it for you.
7. Connect the cluster without plastic housing.
Note: The truck must be in a dead cold state at this point before you can put the temp needle back.
8. Turn the key (but do not start the truck) and place the temp needle on the cluster so it points dead on with the line.
9. Drive around after to make sure the needle starts to move.
Note: If you don't do this your check gauge light will stay lit after less than 5 min of driving.
Getting the same fuel readout as the 9x:
1. Repeat Temp Gauge instructions just swap the Fuel motor.
Getting Indicators to work:
1. Remove cluster by disconnecting 3 harness'.
2. Remove harness locks that are both sides of the connector.
3. Using a Large Paper Clip push in the middle of the harness connections.
Note: the easiest way to do this is push down and slide up toward back end of the connector (where the wires connect to the metal pins).
4. Follow the diagram below to repin each wire to their new place in the 3 different harness'.
Note: The top connector on the cluster is Black (1-12 pins), The right most long white connector is (1-16 pins), and the middle white connector is (1-10 pins)
Dead Link Removed
Dead Link Removed
Final Product:
Dead Link Removed
Dead Link Removed
Dead Link Removed
Finally all I can say is, thanks to all the people who answered my questions and provided the pictures you see above. I will be listing the people later on with pictures. Oh and can I get a Sticky?
Disclaimer:
Thanks go to:
ncranchero
1998Exploder
Dan Whitaker
Tools Needed:
8mm
7mm
6mm
Fork
Large Paper Clip
Dead Link Removed
Answers:
Dead Link Removed
Dead Link Removed
Final Product:
Dead Link Removed
Dead Link Removed
Dead Link Removed
