rangermidtn
- February 26, 2011
- Smyrna TN
- 2004 Explorer XLT 4x4
I have had a request on a how to for the coil overs I did on my Explorer, so I am going to do that. Now on mine I bought a set of used lower arms, but you can use your arms if you don't mind not being able to drive. I used the brackets that's in the pics for my upper and lower mounts. When you get them they come in 2 sizes, both measure up 1 1/2", but one is 1.5" wide, and the othe is 1.25" wide. I used the 1.25", because was the width of coilover eyelets with the bushings installed. Alright our struts measure around 21.25" from the upper mount to the center of the lower mount. On mine I also had a truxx spacer which was around 1.75", so I had a total of 23". So I need a total of 23" between my coilovers and mounts to keep the same ride height. I found some coilovers(QA1's from summit racing) that measured 18.75". My mounts were 3", but then you have to add from the original mount, which on mine was 2". So I had a total 23.75". Alright, for the top spacer I got a 5" round 1/4" plate for both sides. I welded the bracket to it, made sure it was centered and straight. I had to trim about 3/4" of each side to fit in the original upper mount. Alright some pic's of what I have gone over so far.
Upper mounts, also these are the brackets I used top and bottom
My coilovers
My coilovers
