- March 4, 2007
- anaheim hills,california
- 95 ranger 4x4/ 91 X 4x4
Disclaimer
...Before modifying your vehicle, you should seek Professional help..
..Seriously
____________________________________________________________
Two different ways to do a Drum to Disc swap - "Hard" or "Easy"
...The "Easy" way would be to swap in a whole axle from a 95-01 Explorer and if you wanted to change gears at the same time, you could find one with 4.10's..
...A gear swap and a drum to disc swap for about $300 for the rear axle can easily be done for just swapping another stock 95-01 Explorer axle with all already included and if you did the work yourself...
...The "Hard" way is a little more involved, initially costly, and may be a little harder to follow as some of my items are not stock so using the other threads listed may help answer some of your other questions...
Intro:
..This swap is on my 95 Ranger which already has an Explorer first gen axle swap, 4.10 gears and a Detroit Locker...
Ranger info
..Until the 2010 Rangers, Ford still made the Ranger with drum brakes..The First gen Explorers 91-94 also have drum brakes. This swap works for both of the models with 8.8's ( older Rangers had 7.5's) as well as other 8.8 applications.
Rangers came with 28-spline 7.5 and 8.8 axles, except for the FX4 Level II, which came with a 31-spline 8.8 same as the Explorer. Until 2010 All Rangers came with drum brake rear ends.
To retro fit disc brakes onto a 28-spline axle, you need to use Cobra/Mustang parts, with a slight modification.
..The 95-01 Ford Explorer rear axle which comes stock with disc, is a highly sought after axle in the offroad scene and especially amongst Jeep owners so don't be surprised if they seem a little scarce at times to find...
Searching for drums to disc swap info
...There are a number of threads where they swap the whole axle..There are quite a bit fewer threads to find when looking to do a "hard swap"..Each has their own style and some have different modifications..
...Here are a couple to better narrow down your search as which way you may want to go if you so choose to do a "Hard Swap"..
Reference threads
Stock 91-94 "hard disc swap"
Stock "Easy" disc swap
02-03 FX4 or newer Level II Ranger
ScottB's latest Ranger to receive a swap- starts at post #78
Discussion on front and rear brake upgrades-Rangers & First Gens
Warning
..If you are looking for the "Easy way" or the "Cheapest" way, this is not it..
...This swap is not the hardest but it does require a bit more patience and funds to achieve the goal..
...I highly suggest to anyone wanting to do this "Hard Swap" to ask a friend if you can swap their 95-01 emergency brake pads for them first...
Other useful and Notable threads for Reference
Parking Brake Removal and Installation
How to Double Flare a Brake Line
...and without the other info (and drum bashing :bsnicker
supplied by ScottB, I probably would have never gotten this done without his knowledge..
..This is a work in Progress..
Intro:
Ranger info
Reference threads
Warning
