How to bleed RABS ABS Valve | Ford Explorer Forums - Serious Explorations
Dr.Doug
1991 Explorer
I replaced the RABS valve today. I understand that others have bleed this item.
How do you bleed a RABS valve? Must the solenoids be energized?
Thank you, Doug
You should be able to bleed he valve by bleeding the rear wheel cylinders. If you are having trouble getting the rears to bleed, start at the line going into the RABS valve, bleed it, go to the line exiting the valve, bleed it, then try bleeding the rear wheel cylinders.
