the pictures of the tensioner are different on my 94 there is no single bolt it has 3 bolts into the block to remove the tensioner wheels and after removing the alternator.....
I got two loose easy but wouldn't you know that one bolt is not accessible by socket only way seems to be by wrench first thing that happened is one corner of the bolt got rounded off in-between 13mm and 1/2 inch...... of course I started with 13 ..... bottom bolt had to be tightened a different way during assembly than the other two mabe even a different bag a bolts and vodka for the attendant
id rather do it another way than trying to dremel a bolt off
lesson: even though the bolt is covered by a nice layer of pure black dirty grease dosnt mean its insulated you should always try to soak with PB blaster overnight
talkin about a bad gage and to change the stat yea whats that little thing on top of the stat with a wire going to it turning copper green whitey cowlked and rusty
the thing im working on is a spring loaded flow valve(stat) been nice to do all this at once in the vicinity of a bad gage of confidence
stat 6.99 seal that can only fit the stat 3.99 I ran back for gasket material for the water jacket pipe with a can of flush in the radiator thinking ok easy got back to a d in the dirt
