I bought a used valance and fog lights and would like to clean the inside of the fog lenses. They came off a 98 and I'm pretty sure the lenses are glass.. any idea what would be ok to pour in them and let them soak with?
soap and water. maybe you can use a long Qtip or skinny paintbrush to scrub the inside. When you install them with the bulbs, make sure the housing is dry and well sealed. Any water in there causes the bulbs to burn out quickly.
Has anyone actually seen a light housing melt?
I find it hard to believe that the composit material they use will be much aeffected by going from 37 to 50 or 55 watts.
Only thing I have seen happen is the bulbs burn out sooner cause the housing wasnt designed to dissapate the heat caused by the higher wattage and that shortens bulb life.
Just soap and water...Nothing stronger.
I haven't seen one melt, but I have seen cracks caused by heat. The '92 to '95 Taurus SHO used rectangular shaped fog lights like the earlier Explorers. They were notorious for developing a heat crack just above the stock 37.5Watt bulb. No way these pathetic excuses for a real lamp could take an overwattage bulb.
Once I actually looked at them I realized they were plastic. Should I just say screw it and buy different fogs, if so what do you suggest? (Nothing expensive, i'm not spending $100 on fogs...I dont offroad or anything)
You don't need to off-road to get fogs. I have two sets of extra lights on mine. I use one as auxilllary driving lights at night, and the others come on withmy high beams to light up everything. They help a lot when driving in really dark places (no street lights). or long stretches of road.
I dont need two sets, after reading a write up I know how to fool the relay I'm pretty sure. Just need to give the lights a constant ground, like the radio fuse or somethin. I'm just gonna get somethin to fit in the stock fog location since I just bought a valance for that reason.
Been thinkin about gettin Silverstar bulbs and I wanna go with brighter fogs too..why bother burnin them up ya know.
