06bluez
- March 24, 2009
- St Charles MO
- '10 Sport Trac Adrenalin
After lots of research I figured out how to convert an AWD Sport Trac Adrenalin to true 4x4.
You'll need a windows laptop, Forscan with license, an OBDII adapter that connects to your laptop, and the 4x4 button module (7L2Z-14B166-AA)
Update the Instrument Panel configuration
Using Forscan, access the Instrument Cluster (IC) module and updated the 720-01-01 block. Here's what I changed:
Update the 4x4 module wiring
After studying the factory wiring documentation, I noticed that Adrenalin's don't have a fuse or wiring in the F23 slot under the hood. I traced this back and discovered that two wires need to be spliced together on the black connector that plugs into the 4x4 module.
Jumper together the Yellow/Red stripe wire and the White/Red stripe wire in the black plug to the 4x4 module. This gives 12v constant power to the White/Red stripe wire which is not connected from the factory.
Install the 4x4 buttons
Swap out the blank buttons for the 4x4 buttons (7L2Z-14B166-AA). All the wiring is there behind the center console trim.
That's all there is to it! After this change you can now use the low range that has been in your transfer case hiding all this time! After this change there is no difference in how the Auto 4x4 operates and everything works the same as before with regards to the auto 4x4 or 'AWD'. Also having the 4x4 buttons as a quick way to engage 4x4 high is much more convenient than having to navigate through the settings menu in the cluster to change it from 'AWD' to Locked. Now just press the 4x4 Auto or 4x4 High buttons.
From #### 6AF3
To #### 6AF1
To #### 6AF1
