usapadyra
- November 23, 2022
- Ukiah, CA
- 98 Ex XLT 4.0 SOHC 2WD
Hey,
Had the transmission (5R55E) serviced last month. Just a regular pan drop. He said he was able to get about 5 quarts out, and that the fluid was in pretty bad condition.
I'd like to replace the old fluid with as much fresh stuff as possible. I don't have the means to drop the pan again myself, so I got one of those little hand pumps to siphon it out through the dipstick and 8 quarts of Mercon V (just in case).
Had a go at it earlier after a long drive, followed by letting the car sit for about an hour, but I was only able to pull about 1 litre before the tube started sucking dry.
Is there any way to get more fluid into the pan so that I can draw it out? I was thinking of starting the car, holding on the brake and moving through the gears a couple of times.
Would this work - is it even safe to do so? I'd be happy if I can get 1 full gallon out before refilling as much. Drive a few hundred miles and then do the same again...
