Number Twelve
- August 31, 2015
- 15 miles west of Tampa Florida
- 2005 Ford Explorer XLT
The procedure: Remove the ceiling light bulbs that come on automatically. Remove the brown wire in the number 2 position in the center connector of the Vehicle Security Module. Open each front door panel and remove the black/light blue wire from the connector to kill the puddle lights.
Penalties: You lose the auto-headlight feature. You have to turn the ceiling light on manually if you want light.
I call this a Fake because it was just the most expedient way to get the car to stop announcing where I am. There might be other ways, better ways, if you have the time to get into the wiring harness, but 2/3 of this stuff is in the Central Junction Box which is nearly impossible to get at. I would like to keep the auto-headlight feature, and that can probably be done, but not without immense amounts of crawling under the dashboard and cussing the person who put a block of fuses and relays under there.
This does not affect the tail lights, turn signals, or brake lights. You will still light up if you press the brake pedal.
