How To: Install Your Own Shocks
dmont
Seattle, WA
'98 XLT
Does anyone know if the rear shocks require the rubber bushings on the bottom mount? I have a pair of KYB replacement shocks and the did not come with the rubber bushings that are on the stock shocks. I've looked at other replacement shocks online and they do not seem to come with the rubber bushings either.
stevefitz26
2012 Ford Explorer LTD
Rear Shock Install - 5th Gen Explorer
Hi all,
Great info in this thread. Any tips or tricks for installing rear shocks on a 2012 explorer? The rear passenger shock is blown and leaking.
Thanks in advance!
jos
2001 XLT 4WD
Thanks for sharing this great info. I have to replace the shocks on my 2001 Explorer too. Now I am more confident doing it myself. Have to find the right shocks now (lots of time we are driving on pretty bad forest roads).
Deyoecw
2011 explorer
Can you give me info on how to remove the rear shocks on the 5th generation explorer.
toypaseo
Flunked daycare
outside shovelling snow
................ 96 XLT ™
Jake100146
Australia
1996 Ford Explorer
Can I lift my 96 ex with just shock absorbers?
If so what type? I want around 2" lift
I have already don't 2" TT/ aal&shackles.
Thanks all,
Jake
Jason94sport
FL
02 Sport 2WD 5 speed
Thanks!
Got all 4 KYB Gas A Just shocks in just under 3 hours taking my time & with a break. Wasn't overly hard. I didn't need any spay lube or anything. Original shocks were spent at 96K miles.
Meme2
Location
Norcal
CA
1998 Eddie Bauer explorer
With a few common tools, anyone can do this and you'll be saving yourself some cash. Hopefully this write-up will pursuade those of you that are still on the fence about doing your own maintenance into giving it a try. Not only can you save a lot of money by taking care of the simple things on your vehicle, but you will know exactly what work was done and furthermore how it was done.
In this write-up, I'll cover both the front and rear shocks as well as the 5th shock on the rear axle that some of you may have. This install pertains to a 2nd Gen Explorer/Mountaineer without air ride.
FRONT SHOCKS:
Step 1 - Jack one side of the vehicle up... I don't have the luxury of a garage, so I used my front lawn! Also, I had a small floor jack as well as my Explorer's bottle jack just for safety. If you have jackstands, I encourage the use of those as well.
Step 2 - Remove the front wheel of the same side you jacked up... duh, lol.
Step 3 - Remove the inner fender mud guard. It's held in by 5 or 6 plastic push pins. Lay it to the side for now.
Step 4 (PICTURE) - The top nut on the front shock is usually stubborn... my Explorer was no exception. After spraying it with PB Blaster, it still ended up sheering off after about 6 or 7 complete turns. (this occurred on both front shocks) This is good though... the shock will be discarded anyway and it saved me the time of having to remove the nut the rest of the way. Make sure you remove the old rubber bushings. Your new shocks will have new bushings. Notice that in the picture, I'm using a 19mm wrench to foul the shock and keep it from turning when I turn the nut on the top. The nut on the top is a 15mm.
Step 5 (PICTURE) - As seen below, the bottom shock is held in by two fixed bolts and 2 nuts. The nuts are accessed from the bottom. Mine were 13mm. (PLEASE MAKE SURE YOU HAVE SOME EXTRA SUPPORT UNDER YOUR VEHICLE IN CASE THE JACKS GIVE WAY! YOU CAN PLACE THE WHEEL/TIRE UNDER THE FRAME.)
STEP 6 - You should have new hardware with your new shocks. I'm sure some of the sizes vary from each brand/model so make sure you have the correct tools on hand for the reinstall. The reinstall is the reverse procedure of the above.
*NOTE: You shouldn't overtighten the top of the front shock so much that the new rubber bushings are completely squished. Snug the bolt down and then give it an extra turn or two. Stop just as the bushing starts to squish out even with the sides of the metal plates. I plan to go back and apply Loctite. I didn't have any on hand.*
STEP 7 - Reinstall the mud guards.
STEP 8 - Reinstall the wheel.
***THE PROCEDURE IS THE SAME FOR BOTH SIDES***
REAR SHOCKS:
*NOTE: You do not need to jack the rear of the vehicle*
Step 1 (PICTURE) - Locate the bolt pictured below. It's best if you use a 15MM wrench to foul the bolt so it doesn't turn. The nut is an 18mm. I used a 1/2" drive wratchet for removal. You may need to knock the bolt loose with a hammer... just be careful not to mess up the threads. The old hardware is used again for the bottom mounts on the rear shocks.
Step 2 (PICTURE) - Follow the shock to the top mount. The nuts are accessed from the top. They are 13mm.
Step 3 - Reinstall in the reverse order. Your new shocks should have new nuts and bolts included for the top mount. The side pictured above is the driver side and imo, it is slightly harder to access the nuts on that side.
REAR STABILIZER SHOCK:
*Note: I'm a big guy, so I found it easiest to pull the back wheels up onto a wood block for additional room. This shock, imo, is easiest accessed from in front of the rear passenger side tire. Also, my replacement did not include hardware, so the old stuff was used again. There didn't appear to be anything wrong with it, but inspect your hardware to make sure.
Step 1 (PICTURE) - Remove the lower bolt. The nut is facing the rear and in my case it was welded to the mount so it held itself in the place. The bolt size is 15mm.
Step 2 - Remove the upper bolt. Note in the above picture that the upper bolt is facing the opposite direction as the lower bolt. The nut for the upper mount is not welded in place but it does have a flap that hits the frame to prevent it from rotating with the bolt. The bolt is also a 15mm.
Step 3 - Reinstall your new shock in the reverse order.
note if you have front air suspension as well as rear make sure you shut it off before you start messing with your car
FRONT SHOCKS:
REAR SHOCKS:
Note if front has air suspension make sure to shut it off before working on vehicle!
B Install your own camber bushing? Shocks, Suspensions, Lift Kits 6
F how to install hid Shocks, Suspensions, Lift Kits 6
E Trying to install warrior spring shackles Shocks, Suspensions, Lift Kits 11
blueka PA883 BL install issues.... Shocks, Suspensions, Lift Kits 6
A 2001 XLS 4" Superlift install Shocks, Suspensions, Lift Kits 3
Makahveli How do you preperly install front shocks on superlift extended radius arms? Shocks, Suspensions, Lift Kits 0
Tbars4 Superlift Install Instructions-Ranger-BII-and Explorer 83-97 Shocks, Suspensions, Lift Kits 0
P 96 Explorer Sport. What kind of suspension should I install? Shocks, Suspensions, Lift Kits 2
W Shackle install. Shocks, Suspensions, Lift Kits 1
X Shackle Install w/ Tow bar Shocks, Suspensions, Lift Kits 2
R Picture of my halfway done spindle install Shocks, Suspensions, Lift Kits 18
R Help.....Spindle Install Shocks, Suspensions, Lift Kits 3
Makahveli Need Bodylift install/uninstall Help!!! Shocks, Suspensions, Lift Kits 11
Four0Sport Warrior 153 shackles install with pics Shocks, Suspensions, Lift Kits 187
A Wtb 4.56 Gears And Install Shocks, Suspensions, Lift Kits 3
Tbars4 F150 Coil Seats Install and Shackles for TTB suspension based platforms Shocks, Suspensions, Lift Kits 313
M Shackle Install Shocks, Suspensions, Lift Kits 19
G Shackle Install Shocks, Suspensions, Lift Kits 10
MountaineerGreen 4" Superlift Install this Weekend!! Shocks, Suspensions, Lift Kits 41
J BL install front mount woes : my X has cancer !!! (pics) Shocks, Suspensions, Lift Kits 33
M camber bushing install Shocks, Suspensions, Lift Kits 5
E Body Lift Install Shocks, Suspensions, Lift Kits 4
M add a leaf install question and shock question Shocks, Suspensions, Lift Kits 12
I body lift install on vehicle lift? Shocks, Suspensions, Lift Kits 2
E How do you install new shocks on Gen 3 X? Shocks, Suspensions, Lift Kits 1
M shifter extension install problem Shocks, Suspensions, Lift Kits 0
C install BL 2"? Shocks, Suspensions, Lift Kits 1
sn0border88 Superlift Install Tips Shocks, Suspensions, Lift Kits 44
sn0border88 Superlift Install Giude Shocks, Suspensions, Lift Kits 4
S Warrior Shackle Install - Before and after pics Shocks, Suspensions, Lift Kits 7
S Any Average Joe Install Spindles? Shocks, Suspensions, Lift Kits 5
T coil install Shocks, Suspensions, Lift Kits 13
X ProComp 3" Spindle Install Write-Up Shocks, Suspensions, Lift Kits 2
G 02 explorer rear strut removal and install Shocks, Suspensions, Lift Kits 1
N Front Swaybar Install after 4" Superlift Shocks, Suspensions, Lift Kits 5
scott93EB Body Lift install, and Q's Shocks, Suspensions, Lift Kits 39
J Is this a good price to install a lift? Shocks, Suspensions, Lift Kits 5
N 4" Superrunner Install Shocks, Suspensions, Lift Kits 2
J How do you install a body lift? Shocks, Suspensions, Lift Kits 13
E dual stabilizer install help Shocks, Suspensions, Lift Kits 1
G F150 Coil Spacers Install? Shocks, Suspensions, Lift Kits 2
4 New Coil Spring Install Shocks, Suspensions, Lift Kits 2
C Best deal on Monroes and install help? Shocks, Suspensions, Lift Kits 9
S Duff install with extended radius arms Shocks, Suspensions, Lift Kits 1
O install price on body lift Shocks, Suspensions, Lift Kits 4
R Looking for sway bar install tips Shocks, Suspensions, Lift Kits 1
M ? on shackle install Shocks, Suspensions, Lift Kits 2
9 Must the sway bar be removed to install the bushings? Shocks, Suspensions, Lift Kits 2
B install on body lift Shocks, Suspensions, Lift Kits 10
B install body lift? Shocks, Suspensions, Lift Kits 1
Similar threads
