gavin
- September 27, 2002
- Anchorage, Alaska
- '97 Explorer XLT AWD 5.0L
The PA 792 does not come with the right length bolts (for a second gen). You'll be able to use the bolts provided for the front body mounts, the factory (5) bolts for the (2) position bolts after lifting, and one of the not-as-long bolts that come with the kit for the (5) position. You'll need to buy extra bolts, but I couldn't tell you which size will fit where. I'll be doing this lift (again) in one month from today and I've bought M12x130 and M12x120 bolts from the hardware store just as extras.
You don't need to extend the steering column but I advise unbolting before lifting and re installing after lifting.
If you have side skirts/moldings leave them on until after you're done to decide if you still want them or not (they help hide the "hanging frame" look)
the body lift used for probably 99% of the 2nd gens on here used the PA 883 or 853.
I believe I used the 883. Only needed to buy 2 bolts; but could have actually re-used existing bolts if I had done more research on the forum.
