How to: make revese glow gauges come on with interior lights | Ford Explorer - Ford Ranger Forums - Serious Explorations
SkanlaxJMO
Syracuse, New York
96 XLT
Well I have had my reverse glow gauges for almost a year now. And one of my major complaints is that they have a seperate switch and you have to turn that one and turn on your headlights......or if someone drives your truck they cant figure out why the gauges are not lit up. So today I wired them into the interior lights.
Step One
Take dash apart.(there is a good thread on it but if you have done gauges you should know how).
Step Two:
Because the switch on the gauges is not a normal on/off switch it took some creative thinking. What I did was to cut off the end plug that went into the switch(the one that came with the gauges). Then tape off one of the ends. The other strip the end...you will use it later.
Step 3 Now here is the fun part....i spent an hour probing through the wires on the headlight harness and it came that the blue and orange striped wire is the one you want.
So now That you have your wire take the red(power) wire for the gauges and splice it onto the blue and orange wire along with the one wire from earlier that you stripped. Sauder them and tape them up.
As you can see i extended mine a bit........
Gauges come on with headligts/ Running lights.
(no my dash is nto back together yet)
Now if you dont want to pull the dash apart there are alternatives. There is a bulb underneath the center consol that you can chop off run an extension from the positive and tap off of that...(I Did that in the long run because i did not want to sauder inside my dash and i have a couple neon's running off it already).
last step: put the dash back together...and make sure all the electrical connections have heat shrink or tape over them.
Join the Elite Explorers $20 each year.
Elite Explorer members see no advertisements, no banner ads, no double underlined links.
SkanlaxJMO
Syracuse, New York
96 XLT
thanks......camera phone pics....you get the idea though... :p
moose1
coupville, wa
99 xlt
I was going to post a question about this, i have these guages and mine stopped working, meaning they dont light up, any ideas.
SkanlaxJMO
Syracuse, New York
96 XLT
the little switch is probably bad....mine went bad.....what you do is cut off the little ends and then strip both wires and connect one of the wires to a 12v hot wire and if it doesnt work...try the other one......its not like a normal switch. Also check the ground.
dman726749
Greenwood Indiana
96 xlt
hmmm my glow lights wired directly into the headlight switch from the get go, so i didnt have that problem....i do have a switch to chnage from blue to green, and some wires came off the back and the blue side wouldent work anymore...so you might check that out if yours wont come on anymore
SkanlaxJMO
Syracuse, New York
96 XLT
the ones i got are only blue.....and it is awesome not having to hit the switch now...and it is really cool being able to dim them
