Tshark299
- October 29, 2004
- Upstate NY
- '93 XLT
The clutch on my AC compressor seems to be shot. Sometimes it will not fully engage, such that it makes a loud scratching noise and the compressor itself only spins in sporadic spurts. Sometimes it engages and runs for hours perfectly fine, but more and more often now it's slipping so that the compressor only spins a little or not at all.
I'm still running R12 and when the compressor actually spins it works very well, so I'd like to not open up the system if I don't have to, that's why I'm looking to try replacing only the clutch and not the whole compressor. I'm also trying to put as little money as possible into this truck since it has 178K miles on it. The previous owner did a major overhaul to the AC system maybe 6-8 years ago, but they were unsure as to what was specifically replaced then, other than "almost everything".
So I'm wondering how the clutch assembly is removed from the compressor; what the procedure is and what special tools are necessary. Thanks!
