Joe Dirt
- October 4, 2007
- 07 Camry
After doing a few of these now, I figured I'd snap some pics and do a writeup for the masses.
Here is our patient, 2000 XLT V8 AWD:
First step- get your stuff. I ordered the Spectra-Premium radiator from Rock Auto, some Gates upper and lower radiator hoses and a new Motorcraft Rad cap.
SPECTRA PREMIUM RAD CU2308
GATES UPPER HOSE 22310
GATES LOWER HOSE 22452
MOTORCRAFT CAP RS76
On to the fun:
Remove the radiator belly guard. 10mm Bolts
This is where mine was leaking, common- the seam between the aluminum radiator and the plastic tanks. It starts as a faint coolant smell once in a while, with no coolant showing up on the floor.
This is where it goes, and why it doesn't show up on the ground...
Loosen the petcock valve
Drain the radiator
While it's draining, let's go up top and pull some hoses.
Start with removing your airbox cover and stash it up top out of the way. No need to remove it from the throttle body.
Grab some pliers and squeeze and remove the hose clamp on the upper hose.
Do the same on the thermostat housing end. Twist the hose and remove from the vehicle.
Remove the fan shroud. 10mm bolts also.
Set it back on the fan blade, and for convenience, zip tie it back to something to keep it out of your work area. You do NOT need to remove your fan to change the radiator. So, unless you enjoy chasing around the right fan clutch removal tool, don't even mess with it.
Remove the transmission cooler lines. 5/8" on the smaller one, I just used a crescent on the larger for stability.
Removed.
Slowing down, but still draining.
Remove the clamp on the lower rad hose. Leave the other end attached to the engine.
Loosen the radiator retaining bolts. Again, 10mm.
Pop open the clips holding the overflow tank's hose.
Now... The fun part- the infamous clips.
In all honesty, they're not bad- they really aren't. I think the job is way over-hyped. Anyhow, here is how you get the rad out.
Here is the fanny-pack clip.
Process- squeeze the clip together, and use a screwdriver to pry it out while holding the clip. Pry until it comes loose.
Remove the bolt holding the transmission cooler lines and actually their bracket to the radiator. 10mm.
You'll then have this.
Now, let's go back up top to the slide locks.
If you look at this pic, you can see them.
If you look down, you can now see the clips. The radiator has the female portion of the slide lock, the condenser has the male portion.
Since the A/C condenser is loose as well as the radiator, you can now pull, push, and generally have fun getting the slide locks out. The condenser can be pulled as far to the passenger side as possible, and the rad slides to the Driver's side to remove.
Success!
Here are some more pics of the condenser slide locks.
And the fanny pack clip.
That's all there is to removing your radiator.
Now, since you've just done all of this work, you might as well do some more PM while you're in there, so here are the parts you need to replace your tensioner, upper and lower pullies, and the drive belt.
Reinstallation!
I started by putting the protective webbing on the new radiator hoses.
Since I grabbed the new (to me) metal fan from the ('96-'98) V8 Explorer at the yard, I had to get the old junktastic plastic fan out of there.
Grab your Performance Tool wrench. I got mine at O'Reilly's.
I wedged a small crowbar between 2 of the water pump pulley bolts, and cranked the wrench left. Popped loose easily.
Screw that crap fan.
If you only grab the blade, that's fine. You can swap the fanblade unit from one clutch to the other, they are interchangeable.
I was going to replace the water pump, but decided not to. It's doing fine, and I wasn't going to chance breaking a bolt as I'm going to be moving to a new house in the next week... Will need the truck and wouldn't have time to fix it.
Anyway, if you're going to, and need to get the water pump pulley off, remember that you can make a strap wrench from the old drive belt and some vice grips...
I did replace the thermostat, and some heater hoses.
I used:
MOTORCRAFT THERMOSTAT RT1139 (195*F) same as stock
MOTORCRAFT THERMOSTAT GASKET RG605
MOTORCRAFT BYPASS HOSE KM1935
Out with the old thermostat
Off with the hoses
The old thermostat
Why the poopy plastic fan is going away...
Prepping the gasket, thermostat, and neck. I know it's a topic of discussion, but the factory service manual calls for RTV on the gasket. So, I did. Then reinstall, leave hoses off for now.
Radiator set in place.
Slide locks in.
Line up your fanny pack clip.
Slide in the fanny pack clip, and reattach your A/C condenser lines mounting bracket to the radiator.
Lower hose on, reattach to the engine as well.
Reattach transmission cooler lines. USE TEFLON TAPE! Tighten them using a support wrench.
Something I decided to do after reading a warning sticker on the bottom of the rad- I flushed it before finishing.
While that drains, reattach the radiator to the header panel.
Reattach the bypass and inlet coolant hoses to the water pump.
Place your fan shroud in the bay, then the fan blade/clutch. You will notice that at ~11:00pm last night I forgot the damn shroud. More later on that...
Mount your fan if you removed it. Again- you do NOT have to remove the fan to change the radiator...
Holding the fan clutch bolt with the PT wrench, push down on the left most bolt and you can spin the thing on, rather than cranking 30* with each wrench turn. Once snug, tighten the bolt best you can.
Belt on? PITA with the fan on. I figured what the heck- I'll just remove it to put the belt on. No, still didn't notice the shroud yet.
Tip for belt fitting- since it's impossible to get the damn thing to stay in place on the crank pulley and idler down there, grab a bungee, and hook the top of the belt to the hood. It will create some tension, and you can put the lower portion on without it falling off as soon as you climb out from underneath.
Like this:
Belt on.
This is where it went south. I put the stupid fan in again, without the fan shroud. WTF Joe?
So I removed it again. Or tried. I had to have tweaked it so tight the last time I installed it, I could NOT get the damn thing back off. Finally, 2 HOURS LATER, the fan came off, I put in the shroud, put the fan back on, and reinstalled the shroud.
Reinstall the upper rad hose.
Snap your airbox cover back on, and you're done reinstalling.
I dumped in a radiatorful of 50/50 Prestone, started, let warm up, turn off, let cool. Open cap, refill, started, let warm up, turn off, let cool, check level again... Did that 5 times before it stabilized.
Added some ATF to replace what was in the cooler, and checked for leaks. All good, no issues. G-Uniiit!
After checking for leaks one more time, you can reinstall the bottom cover and you're good to go.
Now. That f-ing fan. F that thing. 3 hours later, I looked like this:
That last MF'er is deep! That thing hurt every time I set it up on my desk at work today. Hey- at least I didn't cut myself open, right?
Screw that fan clutch!
MOTORCRAFT CAP RS76
On to the fun:
Drain the radiator
Removed.
Success!
Reinstallation!
I used:
Off with the hoses
The old thermostat
Slide locks in.
Like this:
Belt on.
