How To remove spark Plug #3 | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership!
    If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
Hanover Park IL (Near Chicago)
92 EB 4x4 00 XLS 4x4
i got a 1992 ford Explorer Eddie Bauer 4x4 with a 4.0L V6 i am removing spark # 3 is hard beacuase the blower motor and caseing is to bulky to a socket on :yelexp:
ostfow
cincinnati ohio
1994 sport
Try getting to it thru the wheel well, and use a swivel on your socket.
Jason94sport
FL
02 Sport 2WD 5 speed
Took the passanger tire off & went through the wheel well lining. Got it fairly easy that way.
do i take the front tire off
:exporange doi take the front tire off with out removing the lock out :exporange
did the lock out stay on the front axle
the the lock out stay on the axle
Jason94sport
FL
Lockout??????? Do you mean the locking hub? That stays on or comes off doesn't matter.
Thanks
:exporange
yes locking hub thanks i am 18 and got my first explorer
Darrman
Waxahachie, TX
'92 Sport 4x4/2001 Sport
I got mine off by just putting the socket on first, then putting the ratchet on, worked great. Install was the same.
pinoyesv6
Maryland
'91 XLT
i don't even take out the wheel. i just turn the wheel so its out of the way.
Jason94sport
FL
That could work too. I have big hands, & fat fingers, so it was just easier for me to take the wheel off.
Rhett
Let Them Eat Cake
Cape Girardeau, MO
94 Sport 4x4
I do what was said above, remove wheel, and then I put a swivel plug socket on the plug thru the wheel well...and then fish the extension down thru the engine bay with my right arm while holding the swivel socket with my left arm.
You have to have long arms, I can barely do it, but it works great.
floydfly
Denver,CO
'93 XLT
What a POS design, and biuld. If I wasn't buying this for my sis inlaw, I would never own one. No wonder toyota rules.
Maniak
Moderator-Stock 91-94
Moderator Emeritus
Vail, Arizona
1992 XLT 4x4
You may think that way if you wish.. Just remember, each manufacurer does their own stupid things.. For Example.. Pulling plug 1 (drivers front) from a toyota pickup (v6) is hard to do.. It was behind the a/c bracket... There were many other little issues we ran into (none of us have small hands) when trying to pull the intake of the toyota.. We were cursing toyota all day..
Once you know the "trick" pulling plug #3 isn't so bad.. (I do mine through the wheel well and it is a no brainer for me now.. I'm sure the toyota is the same way, but since it isn't my vehicle I don't care to learn all the tricks..
~Mark
monkeydude3
Millbrook, Illinois
2001 Explorer Sport Trac
I had a 1994 XL and I did a set of plugs twice in my time owning it... I just turned the wheels all the way to the left, and with a little snaking of my arm I got that plug out and in, without a swivel! Just a 3" extension on a 3/8" ratchet. You want spark plugs that are fun just do them on a pontiac grand am... the back three are underneath!
Rhett
Let Them Eat Cake
Cape Girardeau, MO
94 Sport 4x4
The Explorer is pretty easy to do plugs on, come on!! Try changing plugs on a 90-95 Nissan 300ZX! Talk about no underhood space!
monkeydude3
Millbrook, Illinois
haven't done those, but have seen them... amen to that.... the explorer is pretty easy by others that I have done.. My mustang is even easier! On the 4.6 SOHC they are all on top...
peace all
George
mrboyle
I Drive By Brail
Moderator Emeritus
Montrose, CO
'95 Bronco '80 Toy
Ever change a fuel filter on a Toyota? :p
I made mine really easy to get to!
I took a sawzall to the inner fender and removed a chunk of it allowing easier access to the #3 plug as well as the O2 sensor!
Bwana Bob
Morris Plains, NJ
92 XLT
I can get to mine (1992) from above. I put a U-joint on the socket and used a long extension bar. What often happens to me, though, is that I drop the sparkplug and it gets lodged in a little crevice between the body and frame. Really hard to find and get out.
Bob
