The new cordless tool sets give you an option to purchase individual tools without a battery or a charger so you could make your own custom set. The old sets were not like this. They came with a few pieces in a hard carry case. You had an option to purchase only a handful of separate tools, but they came in their own case along with a battery, and a charger. Basically, you couldn't get the bare tool without anything else. For those of you that still use older tools, and want to keep the set working as long as possible, there are several options:
* Special order the replacement parts, and pay more than what the tool is worth.
* Find a working tool on EBay, and use it as long as you can.
* Do a search online for the replacement part number, and see how many tools use this same part.
The third option is a little more work, but if you need to have your tool working as soon as possible, and can't find an exact match as mentioned in the second choice, then this is the way to go. You'll be surprised how many tools use the same electric motor even though the voltage range varies between 14.4 volts & 18 volts. Other parts are interchangeable as well. This is a little known fact that is not mentioned anywhere else other than here.
Here is an example of an electric motor that is used in several Craftsman cordless trim saws:
Part # 975660-000 motor $52.28.
Model number interchange chart:
14.4 volt 5 1/2" trim saw:
973.113080
973.113081
18 volt 5 1/2" trim saw:
315.271810
315.271020
973.113120
973.113121
This concludes the first part of this thread. The second part is about showing comparisons of similar parts from various Craftsman trim saws. Some are similar, and fit perfectly while their appearance might look a little different as far as shape, color, or the writing on them.
973.113080
973.113081
315.271810
315.271020
973.113120
973.113121
