How to replace the blend door?
hockeyadc
NJ
2002 Ford Explorer
I haven't found any DIY's for this anywhere, just the actuator. Do I have to remove the entire dash? If so is there an easy DIY for that at least? I saw some variations of cutting holes, going through the glovebox, etc. If it is not too bad to remove that dash I think I'd just rather do it that way, but I don't want to break anything in the process.
greg0920
essex, maryland
2013 ford explorer xlt
It sucks. If its the passengers side I did one on my sister in laws 2011 Ex. You have to remove the glove box, the trim and then the box itself. you will see the actuator off to the left. The first bolt is easy to get to. The second in shoved in the back. That's the one that's gonna give you the most trouble. Once you get that done its all done hill from there.
hockeyadc
NJ
2002 Ford Explorer
you said passenger side, is there more than one? i can hear it flapping shut when the air is turned up too high, and then its stuck on heat. it sounds like its more towards the middle but a bit on the passenger side maybe?
greg0920
essex, maryland
To give you better info what is the year and model of your ford? I work for a dealer so I can get you info on this issue.
hockeyadc
NJ
2002 Ford Explorer
Awesome. Its an 02 2wd xls. Im hoping to fix this before it gets too hot lol
greg0920
essex, maryland
do you have the dual zone heating and air?
hockeyadc
NJ
2002 Ford Explorer
No just in the front. Manual temperature adjustment
hockeyadc
NJ
2002 Ford Explorer
Also just to make sure, I am talking about the actual blend DOOR not the actuator. I replaced the actuator twice, thats not the issue. I can hear the door physically moving
greg0920
essex, maryland
Sorry I haven't got back you in a while. The site was down. The door I have never done. Sorry.
greg0920
essex, maryland
I found this on youtube.
hockeyadc
NJ
2002 Ford Explorer
This may help thanks. Is there a factory manual somewhere that shows how to remove the dash?
greg0920
essex, maryland
yes you can find a digital copy online. Just google search it. try helms.com
