how to tap into headlight wiring 2016 sport? | Ford Explorer Forums - Serious Explorations
Blues Fan 30
2016 Explorer Sport
I have been searching like crazy and coming up empty. Anyone know where the best place is to tap into the headlights and which wires I will need to tap into? I am trying to add footwell lighting and want the lights to come on when the headlights are on.
Thanks!
I would think the best place would be behind the headlight switch. As for which wire, I don't know, but I believe there are wiring diagrams here on the forum.
You can find wiring diagrams here. BBB Industries- Premium Alternators, Starters, Power Steering Products | TSB's & Wiring Diagrams
Click wiring diagrams, enter your vehicle, choose electrical distribution under system, leave subsystem blank, click search, choose first diagram. It's got headlights and the headlight switch, etc.
Thank you, SIR !!! I think you have solved my foglight issue,
I installed a new headlight switch with the fog light switch I put in some aftermarket Foglights and wanted to run to the BCM. when I push the switch I hear a "Click" which I assume is the relay in the BCM with that site I was able to find the wire Brown/yellow is the power on for fog lights.
I will update if this works.
EDIT: I have Forscan so I will go in and activate Fog lights I have seen this playing around in the program
