How to turn-off all lights with tailgate open?
jedimike
Bremerton, WA
2011 Limited (ordered)
I went to a drive-in with the explorer a couple weeks ago and it was a miserable experience. We were covering all the lights with coats and blankets. The exterior mirror lights are also on. Our explorer was the ONLY vehicle lit up like a Christmas tree. An attendant came to our vehicle and told us to turn the lights off. I caved and closed the tailgate which meant we were all viewing the screen through the defroster lines in the tiny window. Then, after 30 minutes the accessory power warning came on to prevent you from draining the battery. I had to start the truck and let it run... Thankfully it is very quiet.
I came away from the experience thinking next time we'll take the mini and some lawn chairs. Even if the above trick works, the big display puts out a lot of light and you'll get the battery warning. There's no reason why Ford couldn't program in a drive-in mode button or voice command.
artnalex
Los Angeles
2011 Limited
I have a way to turn off the lights with the lift gate open. What I don't know is how long the radio will stay on. I have done this many times and soccer games.
0: Park car turn turn off car
1: Put ignition in accessory
2: turn radio
3: Open lift gate any way you like. .
4: Get a pencil, pen of anything thin
5: Push the latch that locks the lift gate closed, how located above your head on the lift gate
6: Wait about 30 seconds for the interior light to dim then go out
7: Listen to radio, Unknown time, 30 min to 1 hour before the computer steps in a shuts everything off
8: IMPORTANT unlock lift gate manually, push button an handle, Not Button on bottom of lift gate.
9: MANUALLY close lift gate.
Ford and many auto makers have put the switch inside the locking mechanism of the door that control the interior lightss.
Unfortunately, this did not work either.
calb
2012 AWD Explorer Limited
Maybe go post a comment on the Ford facebook account for Ford's "futurist"? (Unfortunately I'm not a facebook fan/user)
I had kind of anticipated using this for the drive-in, but apparently both Explorer and Edge have this problem, and Edge has had it for 4+ years!
t4rest
Mabank, TX
2011 Ltd
I tried one more thing. With the car off push the button of the radio power only. With mine and with the key in the car I pushed the radio button without pushing the start button. The MFT turns on and the radio plays. I don't know how long it plays but no other light turned on. I had a Escort SVT awhile back the also did the same for the radio.
artnalex
Los Angeles
2011 Limited
It worked !!!
calb
But do lights stay off with the hatch open?
artnalex
Los Angeles
2011 Limited
"t4rest"'s second set of instructions have to be combined with his first set of instructions for it to work.
Here is how to get it to work.
(1) Turn-off car completely,
(2) I set my headlights to OFF,
(3) leave key in front cupholder (or somewhere near the dashboard)
(4) push-in the circular radio button with rubber edges to turn ON the radio (do not press the ignition button),
(5) close all doors (but leave them all unlocked)
(6) open tailgate,
(7) manually push the locking mechanism on the tailgate door (use your fingers/pen/screwdriver). You have to push the locking mechanism to the second "click" (otherwise the lights won't go off),
(8) wait 30 seconds for lights to dim, and then go OFF.
(9) When you are ready to close liftgate (DO NOT just close the tailgate).... you need to push the "open" button on the outside of the tailgate door (this means you will likely have to lower the tailgate door halfway to be able to press the rubber button on the outside of the tailgate door).
artnalex
Los Angeles
2011 Limited
We still need FORD to come-up with a better remedy than manually closing the latch ourselves. They need some sort of voice command, macro button, or some Master switch to turn-off all interior lights (even if all doors are open).
stripesace
The Woodlands, Tx
2011 XLT
is there not an auto over-ride setting on the light wheel?
FordService
Official Ford Rep
Dearborn, MI
Spengracin
Fairfield, Ca
2012 AWD Limited
All in fun, do you stand on one foot, while jugling a ball in one hand, and spinning a hoop in the other, so the lights will go off. I'm too old to remember to do alll this for just turning off the interior lights! LOL
t4rest
Mabank, TX
2011 Ltd
No, I stand on my head. It's easier. LOL.:D
calb
Hey, artnalex! :)
Great job with combining the two sets of t4rest’s instructions. I agree that this is a perfect idea for www.TheFordStory.com and it looks like calb already posted the link for voting. :)
Cory
Cory - you should get extra votes - bump it upstairs for us ;)
calb
calb, I forwarded the idea in addition to the www.TheFordStory.com submission. Consider it “bumped”. :)
Cory
See .... this is something I'd never get from Ford Canada :) You're the best! For what it is worth, this issue also is bugging the Edge owners from looking at their forum.
FordService
Official Ford Rep
Dearborn, MI
I do everything I can with all the tools I’m given. ;) Thanks again for being such a fan, calb! :D
Cory
Powderfinger
2011 Explorer LTD
Hello All! I find this to be the most funniest thread ever! I had to register and write a reply. First of all thanks for the great information. We are heading to the drive in this evening and I apply the solutions provided.
Second, the funny part... For those complaining about Ford and the design problems when trying to watch movies at the drive-in. Here you go. Ford Canada is located in Oakville Ontario on Ford Drive. They manufacture the Edge and MKX and other models at this location. Here comes the funny part, Ford Drive extends into 9th line where there is a 5 Drive-in Theatre! It is less than 4 km's from the Ford plant! You would have thought that at least one of the designers would have... too much to ask I guess!
R How can I prevent cabin lights from turning on every time I turn off engine? Stock 2011 - 2019 Ford Explorer Discussion 2
D How to turn lights off when idling Stock 2011 - 2019 Ford Explorer Discussion 39
M Interior Lights/Puddle Lights Won't Turn Off Stock 2011 - 2019 Ford Explorer Discussion 8
C How Do You Turn OFF / Disable Interior Lights? Stock 2011 - 2019 Ford Explorer Discussion 38
P Heater won’t turn off Stock 2011 - 2019 Ford Explorer Discussion 1
D 2016 Driver side heated seats wont turn off Stock 2011 - 2019 Ford Explorer Discussion 5
E Can't turn the AC off Stock 2011 - 2019 Ford Explorer Discussion 8
I Heat won't turn off Stock 2011 - 2019 Ford Explorer Discussion 11
B Wiper doesnt turn off Stock 2011 - 2019 Ford Explorer Discussion 10
M Explorer didn't turn off after walking away with key fob Stock 2011 - 2019 Ford Explorer Discussion 8
C Not Ready For Inspection : Sensors resetting during ignition turn off Stock 2011 - 2019 Ford Explorer Discussion 7
P Opinions/Experiences wanted: Engine won't turn off Stock 2011 - 2019 Ford Explorer Discussion 5
A 4.2" screens in gouge cluster spontaneously and repeatedly turn off and on Stock 2011 - 2019 Ford Explorer Discussion 3
R Help turn off seat memory easy exit stuff Stock 2011 - 2019 Ford Explorer Discussion 15
E Intermittent Noise When Making A Left Turn Stock 2011 - 2019 Ford Explorer Discussion 2
MrWickd Interior lights/puddle lights won't turn on Stock 2011 - 2019 Ford Explorer Discussion 2
T Changing Turn Signal Lever? Stock 2011 - 2019 Ford Explorer Discussion 18
R 2013 to 2019 Upper Strut Mount - Does not turn freely, normal? Stock 2011 - 2019 Ford Explorer Discussion 6
Bobs2018Explorer Upgrading basic outside mirrors to turn-signal mirrors Stock 2011 - 2019 Ford Explorer Discussion 25
T Whelen turn signal bulbs changed Stock 2011 - 2019 Ford Explorer Discussion 0
A Turn signal Stock 2011 - 2019 Ford Explorer Discussion 1
M 2015 Explorer Sport Side Mirror Turn Signal Stock 2011 - 2019 Ford Explorer Discussion 2
Q Right Turn Signal not working Stock 2011 - 2019 Ford Explorer Discussion 27
D Turn Key, wont crank for a few seconds Stock 2011 - 2019 Ford Explorer Discussion 10
Partsman109 2011-2015 Explorer front turn/parking lamp...is there a cool way to minimize the amber? Stock 2011 - 2019 Ford Explorer Discussion 6
M 2012 ford Explorer popping when i turn Stock 2011 - 2019 Ford Explorer Discussion 0
N Question on Front Running lights and turn signals Stock 2011 - 2019 Ford Explorer Discussion 9
J Turn Signal Will not Stay on Right Turn Only Stock 2011 - 2019 Ford Explorer Discussion 5
I Can't See Turn Signal Indicators Stock 2011 - 2019 Ford Explorer Discussion 3
J Emergency lights automatically turn on during emergency braking Stock 2011 - 2019 Ford Explorer Discussion 21
D Cruise control inconsistently works - wont turn on. Stock 2011 - 2019 Ford Explorer Discussion 2
B Turn Signal reset Stock 2011 - 2019 Ford Explorer Discussion 2
T Turn Signal 4 blink problem Stock 2011 - 2019 Ford Explorer Discussion 4
M Changing Turn Signal Lens 2014 explorer Stock 2011 - 2019 Ford Explorer Discussion 0
M Mirror Turn Signal Wiring Stock 2011 - 2019 Ford Explorer Discussion 0
W broken turn signal lens on exterior mirror 2011 explorer Stock 2011 - 2019 Ford Explorer Discussion 0
T Frustration with turn signal lever Stock 2011 - 2019 Ford Explorer Discussion 28
3 turn signal Stock 2011 - 2019 Ford Explorer Discussion 6
P Replace the mirror turn signal light strip Stock 2011 - 2019 Ford Explorer Discussion 19
D Is there a way to turn down the volume for the navigation prompts? Stock 2011 - 2019 Ford Explorer Discussion 10
3 Left turn signal not working..only flashes 3 times Stock 2011 - 2019 Ford Explorer Discussion 13
D A ? for those that have had their turn signal lever replaced..... Stock 2011 - 2019 Ford Explorer Discussion 0
P Notchy Turn Signal Lever FIX Stock 2011 - 2019 Ford Explorer Discussion 65
G Turn signal flasher relay Stock 2011 - 2019 Ford Explorer Discussion 34
P 2013 Explorer: Ticking Sound and RPM issue when A/C is turn on Stock 2011 - 2019 Ford Explorer Discussion 5
S Turn signal oddity Stock 2011 - 2019 Ford Explorer Discussion 6
S Radio won't turn on Stock 2011 - 2019 Ford Explorer Discussion 57
S Emergency: 2011 Ford Explorer XLT right turn signal stuck, won't cancel!! Stock 2011 - 2019 Ford Explorer Discussion 28
D I swear I hear a fan noise when I turn on my Heated Seats. Stock 2011 - 2019 Ford Explorer Discussion 9
N You can remove your seat belt while driving and no "belt minder" will turn on Stock 2011 - 2019 Ford Explorer Discussion 12
Similar threads
