mcnulty6807
- November 25, 2006
- Alexandria, VA
- 2000 XLT V8 5.0
Once again your post saved me lots of $. Thanks a lot.
Has anyone had problems getting the new upper bj back into the knuckle? I have jacked up underneath the knuckle and pounded on the top of the bj and it won't go all the way in for the life of me. Plan b is to heat up the spindle with a torch to try to get it to expand a little and plan c is to put grease in it after it cools down. Suggestions?
Also, I bought a camber washer set for the upper control arm but not new bolts. Am a little concerned that the alignment shop is going to tell me i need new bolts, and i want to put them in now if i need to before i take it over there. Do I need the new bolts or will the camber washers be sufficient?
So, what worked for me was:
