How to Wire Auxiliary Reverse lights that come on in reverse
dogfish246
New Jersey
2002 Ford Ranger V6 4x4
Hey guys,
This video shows you how to wire auxiliary reverse lights so that they come on when you put the truck into reverse. I know wiring scares some people but it really isnt that bad.
Let me know what you think of my setup!
chefduane
Texas Elite Explorer
Location
TEXAS!
Plano, TX.
None: SOLD 9/16
Nice write-up. My problem is a location to put the lights. I have a tow bar and trying to find someplace to mount lights is a pain.
dogfish246
New Jersey
Even with a tow bar, these lights fit where I put them. I am planning on getting a tow bar so that is why I put them where I did.
bnizzel2000
1998 ford explorer
thanks for the great write up i just did mine today and they work great so far ill post ome pics as soon as it gets dark
istroo
Brighton MI
2000 Ford explorer
Great video!
Been thinking about doing the same thing and your video shows how easy it is.
:thumbsup:
bnizzel2000
1998 ford explorer
here are a few pics of mine all set up and working these are 5 inch masionte lights
dogfish246
New Jersey
:thumbsup:
It really is not bad at all. It was a lot of fun to do and the results are the best part!
Those look awesome! Nice work!
Flash
Brisbane Australia
1997 Limited
I don't like the mounting position of those lights, wouldn't they hit if you drag your arse out of a ditch?
I've thought of mounting reversing lights on the bolts that go through the hatch glass. I haven't looked too closely at it though.
You could tap the reverse wire on the factory tow loom.
When tapping a wire, I prefer the cut the wire and slip a piece of heat shrink tube on then solder all 3 wire ends together then shrink the tube over the join.
A Help! Wire routing question for aux driving lts. Performance Lighting 4
F What Gauge wire. Performance Lighting 4
T Offroad light wire help Performance Lighting 2
D Standard Copper Wire vs Silver Coated Copper Wire Performance Lighting 3
J High Beam Wire Performance Lighting 3
D Allternator wire burnt in to Performance Lighting 4
minelson17 HELP: Best way to wire roof mounted Aux Lights Performance Lighting 3
W Wire a switch to manually turn on the puddle lamps? Performance Lighting 8
S high beam wire Performance Lighting 5
D 2nd gen puddle light wire (color and location) Performance Lighting 3
BigRondo Wire Routing Performance Lighting 2
R Can I wire Off Road Lights to stock switch Performance Lighting 4
J low beam light wire ? Performance Lighting 1
D running light wire Performance Lighting 0
F Cant find headlight wire Performance Lighting 0
J HID relay wire harness question Performance Lighting 6
D installing resistor for LED turn signals (which wire to tap in?) Performance Lighting 10
B el glow wire questions Performance Lighting 1
C Where to wire third brake light on 01 Sport Trac Performance Lighting 5
B How to wire these fogs the correct way? Performance Lighting 4
B Trying to wire after market Fogs. Which is positive? Performance Lighting 5
J Pacer Tailgate LED Light Installation - Does '07 X have constant power wire at rear? Performance Lighting 4
E 2006 4 way wire harness Performance Lighting 8
little x 5 pin relay wire guide Performance Lighting 4
W best place to wire? Performance Lighting 6
Minivek how to wire a 3 position switch to turn on 2 or all 4 bulbs Performance Lighting 6
DB_1 Trying to wire up LED tail/turn/stop lights... Performance Lighting 22
D Highbeam wire color? Performance Lighting 7
I Heavy-duty wire harness Performance Lighting 4
N Positive, ground wire terminal question Performance Lighting 8
M Guage light wire Performance Lighting 4
toddious which wire do i splice from high beams? Performance Lighting 13
C Wire size Performance Lighting 2
M what guage wire? Performance Lighting 10
J re-wire fog light swich to be always on? Performance Lighting 8
C Reverse Light Wire Performance Lighting 3
S headlight mainbeam circuit wire for 97 Explorer Performance Lighting 4
Gofast PIAA Pro 80 XT, Which wire goes where? Performance Lighting 5
P help me wire driving lights with relay- Performance Lighting 7
M How do u wire 3-prong switch Performance Lighting 5
L How did you splice into bright headlight wire? Performance Lighting 2
T '02 high beam wire Performance Lighting 2
M Wire harness help Performance Lighting 3
RangerX Only one wire? Performance Lighting 4
E HELP! How to wire side markers? Performance Lighting 3
Y Hot parking light wire in a 2001 Performance Lighting 2
B How to wire windshield washer lights to a switch? Performance Lighting 4
B Hooking Up Neons to 10 guage wire??? Performance Lighting 3
Y HELP What else? How to wire foglights Performance Lighting 15
J wire overload? Performance Lighting 12
Similar threads
