Cheeseguy
- July 20, 2015
- Worley, Idaho
- 1998 Explorer 4.0 OHV
I have been browsing this site for a week or so getting some really cool ideas. I just acquired my first explorer, a 1998 Explorer 4.0 OHV 4 door 4x4. I bought this off of craigslist for $1000 with 114k miles as a "mechanic's special". The previous owner had parked it 3 years ago when the fuel pump quit. He said he went through what sounded like a logical procedure for diagnosing a fuel pump failure, so I decided to go ahead and buy the vehicle. He showed me that it ran when gas was squirted in the intake. It had good oil pressure, moved under it's own power, so the tranny was at least capable of moving the car. Has a spotless clean interior, and a flawless body and good glass. I purchased a fuel pump and am getting ready to install it. I saw one of the posts where a hole was cut in the floor pan rather than dropping the fuel tank. This sounds much better than going through the hassle of dropping the tank. Being a fabricator, making a replaceable access hole cover sounds like a way better plan should it ever be necessary to do this again.
However! After reading a bit more, I'm beginning to wonder if the pump is really the problem. My theft light is blinking non stop every couple of seconds, whether the key is on, off, removed, cranking, etc. I only got one key with the vehicle when I bought it, and I hadn't even heard of the PATS system up until now. I will probably go ahead and cut the hole in the floor, just in case I do have to replace the pump, but, at at rate, it will make diagnosis easier.
Thanks in advance for the information I have already gleaned from this site.
