HP and altitude | Ford Explorer - Ford Ranger Forums - Serious Explorations
HP and altitude
rumney510
Denver, CO
2000 XLT V8
Hi does anyone know what happens to your HP at higher altitudes, 5000 ft and 10000 ft ?
also what is the high altitude package and does it affect the superchip?
thanks all
andy
2000 XLT
sink
PA
1994 XLT
I barely should be replying, don't know the explorer specifics to give you a great answer and I won't touch the second half.
Are you looking for specific curves of HP versus altitude or general info?
JDraper
Somewhat Functional
Moderator Emeritus
McVeytown, PA
'18 XLT
I can't give an exact answer either, but as you go up in altitude, you will definitely lose horspower. There is less oxygen in the air, and that is less for the motor to burn.
I believe the high altitude package is primarily a computer (and maybe fuel injector) package that recalibrates your computer for a leaner burn due to the lack of oxygen. I would suspect that the superchip and high altitude packages would not go together really well, but you would be better off asking the Chip manufacturer that question.
jimbo74
Elite Exploder
Nor*Cal
2001, F150, XLT 4x4
yeah, the engine really bogs in higher elevations. I went on a snow trip last week and my check engine light kept coming on intermittently. and when I would gun it it would barely move.
Robert
Location
CA
Kelseyville, CA
'13 Ram 1500 Longhorn
thanks all
andy
2000 XLT
Every 1000 feet in elevation you go up above sea-level you loose 3%. So assuming your engine is the 210 HP SOHC, you would have 180.3 HP at 5,000 feet and 154.9 HP at 10,000 Feet.
