midnightsun
- January 13, 2014
- Paradise
- 2022 Explorer ST
So im told and keep reading that the HPFP is our problem with getting fuel to the engine to make more power.
If i read things right as i learn about HPFP the flow rate increases as RPM increase because the cam lobe can open and close the HPFP piston faster. This means fuel supply is consistently increased as RPM increases.
So why can a f150 blow away our explorer ecoboost on the dyno?
Some numbers are outrageous. 526 Torque and 408 HP on 93 fuel?
http://www.morepowertuning.com/2015-f150-ecoboost-tune-descriptions
Regardless of the dyno charts i see they all seem to taper off at 5K except FullRace charts with the upgraded Compressor wheels.
http://www.full-race.com/store/ecob...-5l-stock-replacement-twin-turbo-upgrade.html Theirs keeps climbing as the engine turns faster. 475WHP
This follows what i've read about the HPFP.
https://www.goapr.com/products/fsi_fuel_pump.html
It would seem the turbo Compress wheel itself is having a drastic effect on the amount of air our little turbos can compress.
Question = why can the f150 ecoboost supply more fuel then our ecoboost? (if it really can)
Question = why is the current turbo compressor wheel so inefficient vs the new?
100hp up top is a huge difference.
Question = why aren't tuners increasing the engine RPM if fuel can continue to keep up?
Is this from the valve springs being weak at higher RPM and reaching float?
