hillre51
- July 13, 2013
- vine grove, ky
- 2003 explorer eddie bauer
Good afternoon, I've a 2003 Explorer (Eddie Bauer) 4.0 engine with 120K miles. Problem: Hearing a very aggravating humming noise at right rear (seems like from the driver's seat). Thus far, jacked up rear end and grabbed tire at 3 & 9 o'clock position and 6 & 12 o'clock position. No play in either of the rear wheel. I did notice the left rear rotor had lot of rust build up. Used wire brush to remove excess. Still hearing humming noise. I'm assuming it's the hub bearing although can't find any play in wheels. Also need to know if a bad tire can cause a humming noise like this. Have any of you had this problem? If so, how did you resolve it. Per my internet research, replacing the rear hub is alot more work than the front due to having to unmount upper and lower balljoint, toe link, emergency brake cable, etc. If so, I suppose I will have to take to a shop. Hope to hear from somebody). Have a good day
