    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership!
Humming not from bearings
ButterBean757
Poquoson
2007 explorer xlt 4.0 2wd
2007 explorer 4.0 xlt 150k 2wd
I have been driving myself crazy trying the fix the wife's explorer. I figured it was time to ask for help.
The humming is constant and gets louder while turning right which lead me to believe it was the wheel bearings. I changed both front TWICE. Still humming. I even swap right and left bearings to see if anything changes. Nope.
I got her to drive all over the place while I ping ponged around the inside listening. I sounds like it's centrally located so I'm not sure exactly where is coming from.
I also rotated the tires three times. Still humming.
When I say humming I mean it sounds like I have 35 inch knobby tires going around a right turn at 40mph. It's not grinding or thumping.
Any help would be greatly appreciated
Bean
Edit...changed all 4 end links also
07EddyB
Bowling Green, KY
2007 Ford Explorer 4.6 V8
Have you changed the rear bearings yet? At 150K they are certainly due.
ButterBean757
Poquoson
I have not changed them yet. I don't have a bearing press and from what I can see I will need one to change them or swap out the whole assembly.
The is louder in front
Explorer_PL
Rockland County, NY
06EB V8
Don't get fooled with the noise coming from the front. I did same thing like you: replaced the front hubs since they are easy while the bad one was one of the rears.
With yours being 2wd, jack up the rear, put it on the stands, choke the front tires and put it in gear and get down there with a stethoscope.
Listen to both bearings but also the diff and the output bearing on the tail piece of the tranny.
ButterBean757
Poquoson
Should I put the stethoscope directly on the bearing hub? I assuming the vehicle should be in gear to check correct?
Explorer_PL
Rockland County, NY
06EB V8
The car has to be up on the jack stands (be careful), car in D and the wheels spinning at about 30-40 mph. I always listen to them from under and inside listening to them from behind the wheel. If one is shot, you will hear the difference. Also, while the car is up, check for play in the rear wheels. If you are lucky, the bad one might have detectable play. What I did before I build a press at home, I would remove the knuckle with the bad bearing, remove the brakes, and take the assembly to an auto shop just to press the old one out and press the new one in. That would save me money on all the labor I could do at home.
Hope that makes sense.
Good luck.
PS: Thanks for you service !
Larryjb
2008 Ford Explorer
Bean
You say you changed front bearings, but not the rear wheel bearings. It sounds like it's the rear wheel bearings that have gone.
ButterBean757
Poquoson
Good luck.
Right on I'll give that a try this even. I get irritated when I can figure something out lol and I refuse to pay for something I can do my self.
Explorer_PL
Rockland County, NY
06EB V8
Digitalgp
Hudson valley
‘07 Limited & ‘15 XLT
Could be your rear bearings. Sometimes the noise reverberates through the chassis in strange ways.
Could be your tires too especially if they are nearing the end of their life (some are also more prone to noise). I had that on my first Fusion. I replaced both front wheel bearings and still had the noise although seemed to be slightly less. All 4 wheels were solid (no play). After putting new tires on it was quiet as a church mouse
Gary Crist
Location
TEXAS a whole different country $1K Green AWD
TEXAS
1997 AWD V8
Callsign
KI6FG
Tires are now designed to make more noise as they wear out.
You might consider replacing the tires before replacing anything else.
Larryjb
2008 Ford Explorer
I like this idea of using a stethoscope. When my rear wheel bearing went, I had to take a bit of a lucky guess. One front one was recently done, the other was done by the previous owner, and the right rear was also done by the previous owner. My noise got louder on right turns indicating a left rear wheel bearing. My guess was right.
I had no play in any of the hubs, front or rear. I could hear no difference in the hubs by ear. Both hubs were the same temperature as far as I was able to measure them.
If I had used a stethoscope, I could have compared both noise from both hubs, then changed the noisier one.
Of course, if one rear hub is going, the other will soon follow, so you could just change them both at once and be done with it.
ButterBean757
Poquoson
That's what Im guessing is the problem. It's just crazy that it's so loud up front. I'm trying to find the time to get to it. She's driving my dodge and I want it back lol
Tommylee1282
Manville, NJ
1999 Ford explorer xlt
Have you checked the differential fluid? On my old 04 explorer, I had a Hum that I misdiagnosed as a bearing, changed the hub, it was still there, changed my front diff fluid and it went away
ButterBean757
Poquoson
I haven't checked it but I will now. Thanks!
Tommylee1282
Manville, NJ
No problem, I also had the drivers side rear bearing go twice on the same vehicle. The first time there was no hum but the rearend would Go all over the place when I went over bumps. The second time It sounded a bit like a brake squeeler Good luck
Explorer_PL
Rockland County, NY
06EB V8
Squeaky rear brakes is one of the indicators of failed bearing. The pads and shoes are in fixed position while the rotor is attached to the hub and bearing. If there is any play in the bearing, the rotor will "dance" and touch the brakes.
robert capdevila
Greenwood sc
2001 sportrac
Bean
Check your drive shaft
