Biniecki
- December 9, 2013
- 1996 Ford Explorer
I recently noticed that my HVAC temp does not seem to be as hot as it use to be. On max heat it feels like it might be a measly 50 - 60 degrees F. I started to notice this shortly after i received a check engine light for my coolant temperature sensor. I am not sure if the problem may be a result of this sensor being bad or possibly bad blend door or thermostat. Any guidance is greatly appreciated. Thanks
