HVAC Front Air Vent Vacuum Motor Access | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership! If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
miltm4444
2008 Ford Explorer
My 2008 XLT has fallen victim to a common problem, no AC to the front dash vents because the vacuum motor controlling the air panel is no longer connected to the air panel control arm due to failure of the plastic pin securing it. That said, how in the world can I get physical access to these parts so that I can perform some kind of makeshift repair to reconnect them. Working through, and under the glove compartment area I can barely get my fingers on the parts, yet alone see them. Would removing the radio and HVAC control panel be of any help getting access to this area? Have seen several threads providing repair methods, but none explain how to get in there. I'm 88, with a worn-out back, so laying on the floor, feet out the door won’t cut it. Meanwhile, I have a wooden dowel poked in the front air vent keeping the air panel open. Works fine, but would be nice to get the HVAC vent selector control working again. Thanks for any help provided.
Holiday Special! Join the Elite Explorers $20 for 2 years! Gets rid of the ads!
94Eddie
2010 Mountaineer Premier
Have you tried finding YouTube videos? This is usually where I start when making a repair I am unfamiliar with doing.
miltm4444
2008 Ford Explorer
Thanks Eddie. I found some excellent repair info on YouTube for my problem but I just can't access the parts like the some guys. Working through the glove box opening I can barely see the broken vent lever, yet work on it. Was hoping to find a better way to get at it.
94Eddie
I know what you mean about about accessing places. I used to crawl under, in and around vehicles like a squirrel but these days not so much. It isn't too hard to remove a seat to gain easier access if you have a little help to lift it out.
miltm4444
2008 Ford Explorer
Thanks for the tip. Right now, it looks like the wood dowel will be there for a while.
