BTR
- April 1, 2011
- MARIETTA, GA
- 2000 XLT 4.0 SOHC 4DR 2WD
2000 Explorer XLT 4-Door 2WD 4.0L SOHC.
While replacing the spark plug wires, I accidentally broke a part. I don't know what the part is. I have to order a new part, but I need to know what it is. Can you tell me what the part is called?
It's located on the driver's side of the engine. It's black and about 3" wide x 2" tall. It's attached to the vertical side of the valve cover by 2 small bolts (approximately 6-8mm hex heads). It has 2 small rubber hoses (approximately 3/4" OD) attached to the bottom and an electrical connector attached on the right.
Both of the rubber hoses broke off of the bottom of the part.
Two questions:
1. What is it?
2. Can I drive with it broken? What would happen?
Two questions:
1. What is it?
