koda2000
- September 2, 2011
- x
I was taking my 4.0L SOHC engine apart and I got to the harmonic balancer removal. Months ago I'd watched several YouTube videos on different ways to do it and I should have gone back and re-watched them because I remembered it wrong (combining 2 separate methods). I'd recalled how I used to remove alternators from BMW motorcycles and thought it was the same procedure. You remove the bolt in the center, put a piece of shaft in the hole, reinstall the bolt and tighten it. It pulled the alternator off the end of the cam shaft. The difference was that the alternator's hole was threaded - the SOHC harmonic balancer is not. Tightening the bolt did not pull on the balancer, but I managed to get the little piece of shaft stuck deep in the crank shaft hole. I tied a magnet to pull it out but it's stuck and will not move.
I watched the videos again and saw that the guy removed the HB bolt and inserted a rod that he pushed against with his standard 3 hole puller. This pulled the HB off the crank shaft. The other method involved using a longer bolt in the crank shaft hole and pushing the 3 hole puller against the bolt, backing the bolt out as you went.
So, now I have to go to the hardware store tomorrow and buy the weird size bolts needed to screw into the HB's holes (8mm x 1.25 90-100 mm long) and maybe a 4" bolt with the same threads as the OE HB bolt to push against the 3 hole puller.
Once the HB is off I'll have a slightly better view and access to the stuck piece of shaft in the crankshaft. Maybe I can drill it and easy-out it out, but even if I can't get it out I think I have enough threads remaining for a correct length HB bolt to grab on and the bolt is only torqued to 37 FP + 90 degrees. I guess the crankshaft's threaded hole is slightly tapered at its end and that's why the end of the little piece of shaft is stuck in there... ? I'd made the shaft out of hardened upper ball joint pinch bolt, so it shouldn't have mushroomed.
Anyway, I've learned a lesson to not trust my aging memory. Watch the videos again just before trying a procedure I'm not familiar with.
