I don't know which transmission I have. | Ford Explorer Forums - Serious Explorations
refg3880
utica ny
2003 eddie b
i have a 2003 4.0 v-6 awd eddie beauer explorer
the tranny is slipping in 3rd gear check engine light is on and pulls code po772 shift solenoid e stuck on.
want to buy a solenoid pack for it but i dont know which tranny i have, are the packs for the e, w, s the same?
the door sticker says tr code v.
the vin is 1fmzu74k13ub68609
also will replacing the pack fix this problem? really cant afford a 1500 dollar rebuild
thanks
You have a 5R55S transmission. Check the internal wiring harness, and the bulkhead connector before you order a solenoid block.
thats the 5r55s is it not?
Oops, my bad I didn't look closely enough, the v trans is the 5r55s not the w but the wiring checks would be in line.
