  • We are aware of the issue with our internal search engine and we will be bringing it back online shortly. For now please use the Google search bar near the top of each page. Thanks, Rick
I got the window motor blues!
Robrt32
Sledge Mississippi
94 Explorer XLT
I been trying to fix my left rear window motor. I have 3 different motors and I can not believe ALL 3 are doing the same thing. It will roll up like a champ but wont roll down. I took it back out and plugged it in , it won't turn the motor but that one way.. Its HARD for me to believe all 3 motors wont turn but one way. I checked the voltage 11.06 on each pin as push the button.It will only work the one way with switch on the rear door AND the switch on the master panel on the drivers door, I wouldn't think the switch could bad on the down position on BOTH doors? seems unlikely. ANY ideas?
I JUST went back out there before I posted and took the panel off the passenger side rear door and plugged all 3 motors in and they turn perfect in both directions!!... I"M BUM-FUZZLED!
Tbars4
Moderator Emeritus
Elite In Memoriam
anaheim hills,california
95 ranger 4x4/ 91 X 4x4
...It sounds like a common button/wire problem...Did you try using the drivers buttons to activate the rear window motor??
Rob816
Jim thorpe,Pennsylvania
1993 Ford Explorer 4wd
Robrt32
Sledge Mississippi
94 Explorer XLT
yes, does the same thing... I just checked the voltage on the passenger side and has 10.06 on both pins, slightly less but it works perfectly
Tbars4
Moderator Emeritus
Elite In Memoriam
...Usualy IIRC, the problem results start at the main panelat the drivers door...Check voltage in/out for both rear windows there first...
...If the pass rear is still lower voltage going out than it is coming in, it is probably that button giving you some problems...Otherwise, it could be the wire in to that and the rear pass window button that has a loose or bad connection...:scratch:
Robrt32
Sledge Mississippi
94 Explorer XLT
I changed ALL the switches, same thing.. I can check it with the voltage meter and got 13 volts on both pins with the engine running.. I give up, I have the right current all the way to the motor just like the other side but yet the motor wont turn.. Its haunted or just not meant to be
Drednaut
Wayne, Michigan
92 eddie bauer 94 navajo
more than lilkely the master switch on the drivers door is bad
D got my electrical diagram today Stock 1991 - 1994 Explorers 1
C got turn signals and hazards, but no brake lights Stock 1991 - 1994 Explorers 5
G Bought a 94 XLT--got a deal Stock 1991 - 1994 Explorers 7
W Just got a 94 Mazda Navajo 4x4 LX Stock 1991 - 1994 Explorers 1
D finally got it running. Stock 1991 - 1994 Explorers 7
L Got the bad news today, headgaskets... Stock 1991 - 1994 Explorers 17
B Need help got 94 explorer Stock 1991 - 1994 Explorers 4
A Just got a 93 Mazda Navajo ( one owner ) Stock 1991 - 1994 Explorers 14
B finally got my explorer running Stock 1991 - 1994 Explorers 6
C Just got a '94 Explorer Stock 1991 - 1994 Explorers 17
R Got less than 6000 mIles on 1993 Explorer rebuilt tranmission Stock 1991 - 1994 Explorers 14
D i'm new here and got a few questions Stock 1991 - 1994 Explorers 3
D I got a hole in my muffler, what should i do about it? Stock 1991 - 1994 Explorers 14
M Truck got broken into Stock 1991 - 1994 Explorers 2
U (Fixed) 92 Explorer 122 Trouble code (this guy got super lucky) Stock 1991 - 1994 Explorers 10
T need help got questions and codes Stock 1991 - 1994 Explorers 39
4 Got some questions on my setup Stock 1991 - 1994 Explorers 10
A Got a few 93's, got a few questions Stock 1991 - 1994 Explorers 6
M i've got oil leaking from my oil filter mount Stock 1991 - 1994 Explorers 5
C got a booboo Stock 1991 - 1994 Explorers 5
E Need Advice on 94 Ranger I just got Stock 1991 - 1994 Explorers 15
C got my explorer sunk in some water and wont turn over anymore Stock 1991 - 1994 Explorers 3
V 1994 Ford Explorer. Lower manifold was removed, and coolant got everywhere. Stock 1991 - 1994 Explorers 10
D Got another Navajo Stock 1991 - 1994 Explorers 6
StryctNy9e got my truck stuck bigtime NEED HELP!!!! Stock 1991 - 1994 Explorers 60
T Just replaced Tranny modulator, now i got shifting problems - HELP! Stock 1991 - 1994 Explorers 14
9 x got sea foamed and nothen Stock 1991 - 1994 Explorers 3
S Got a fully tranny service today at the dealer Stock 1991 - 1994 Explorers 1
J Got trouble codes pulled. Now how to fix them?? Stock 1991 - 1994 Explorers 2
M Finally got my tranny fixed, back in action Stock 1991 - 1994 Explorers 9
K Check out the sweet deal I got on my 91 Explorer! Stock 1991 - 1994 Explorers 16
9 i got a free 91 navajo 4x4!! Stock 1991 - 1994 Explorers 4
Przybysz Got a big radiator problem... Stock 1991 - 1994 Explorers 9
T Master switch on a 1994 Ford Explorer XLT got melted! Stock 1991 - 1994 Explorers 3
D My '91 Explorer got a rotten egg smell sometimes Stock 1991 - 1994 Explorers 7
T new truck got here yesterday Stock 1991 - 1994 Explorers 4
N Got this part thinking it was something else, does it even fit the vehicle? Stock 1991 - 1994 Explorers 1
R Got a new truck! Stock 1991 - 1994 Explorers 9
F Got brake feedback? This may be why.. Stock 1991 - 1994 Explorers 2
B what stat you got Stock 1991 - 1994 Explorers 7
doonze RednecK Mechanic heyday, lots got done! Stock 1991 - 1994 Explorers 1
jtb1689 Put in a new radiator, got problems. Advice? Stock 1991 - 1994 Explorers 22
T New and got a few questions Stock 1991 - 1994 Explorers 1
H 93 Sport - Won't Start - Here's what I got so far... Stock 1991 - 1994 Explorers 1
N hello just got a 1994 XLT FOR $200 ONLY PROBLEM GOT A BLOWN HEAD GASKET AND 225K MILE Stock 1991 - 1994 Explorers 5
SwaintaN YAY, i got em Stock 1991 - 1994 Explorers 0
S Another noob, Another "got search" Question Stock 1991 - 1994 Explorers 1
C I got a new(to me) EX Stock 1991 - 1994 Explorers 11
9 my ex got stolen need help Stock 1991 - 1994 Explorers 5
M I've got one for ya Stock 1991 - 1994 Explorers 9
Similar threads
