keeprollin
- April 26, 2007
- Apex NC
- 94 XLT 4x4
Hi I recently bought a 94 explorer xlt 4x4. I new it had trans problems when I bought it thought maybe it would be an easy fix. The problem I having is this There is no over drive but all other gears work. I also have no cruise control. The guy I bought it from also said that in order for the trans to shift under load is to let off the gas a little then it would shift. But I have read alot in the fourms here. Also when you select overdrive the engine idles down like it does in any other gear like its getting ready to pull but when you give it gas it just doesnt go if you are on a incline it will just start to roll backwards.Like its in N and not od. I have changed both solenoids in the valve body cleaned it out.put new seperator plate gaskets on. New fluid and filter. I also adjusted the bands. But still no over drive. I used my code reader and only got egr valve code which I intend to change. I dont have a trans code reader though. I want to change the od servo but just wanted some more input on what to try next if the servo doesnt do the trick. Thanks
