I just blew up my Explorer!!! Ahhh!
mikeh
St. Louis, MO
98 XLT SOHC V6
I just drove my Explorer 2 miles with no oil in it and I toasted the engine I think. I changed the oil and the filter ended up threaded wrong. I dumped 5 quarts in and I never noticed it all drained onto my driveway!!! My wife drove off in my Explorer this morning and got two miles before she noticed that something was wrong. It didn't have a drop in it. She called me and I went and found the problem and fixed it and drove it back but the damage is done.
The engine now makes a loud clicking sound. And the oil pressure guage jumps from 0 to normal when I'm idling.
I parked now until I find out more or drive it to the junk yard.
Any idea if it might be fixable? It's a 98 Explorer with 135K miles on it.
I'm starting now to look for a new vehicle. Don't know what I want yet.
Ug I'm mad! I've babied the hell out of this car hoping to get a lot more miles out of it.
mikeh
410Fortune
River Season
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
Callsign
FOURTEN
Wow I am sorry to hear this!
It is VERY important to start up a vehicle after an oil change, always look underneath for leaks while it running.
First thing to do is check for oil pressure or an oil light.
Then let it warm up to operating temp, shut it off and check the dipstick again.
You can likely buy a replacement engine for $500-800 and it takes 8-12 hours to swap them out.
Papa
Clearwater, FL
97 Eddy
You did not say if it was synthetic oil or not. 410 is right about checking we have all cleaned up at least one mess. You could do some compression checks, use a bore scope and look inside each cylinder, use a stethoscope and narrow down the location of the click but the prognosis is not good for this engine.
tawd77
kansas
Look inside the cylinders? Thats the last thing thats going to be damaged from oil starvation. He shelled the bearings. It is fixable, but not worth it. Just get a lower milage used engine from the salvage yard. Next time you make a dumbass mistake, try not to make it a $1000 one.
David Suesz
SE PA
1997 Mountaineer
Even when you do everything right, bad things can happen...
coupla years ago my wife drove her just oil changed car to work. Smelled like hot oil when she got there, and looked uner the front end, to see a small puddle of oil. Seems the new filter was defective, and the seal was allowing a drip. Just a little worse, or a little farther drive, and disaster could have resulted to her one-year-old car.
mikeh
St. Louis, MO
98 XLT SOHC V6
Well I'm buying a new engine from a guy for $500 with 64K here locally to drop in the Explorer. We'll see if I can do a better job changing the engine than I did changing the oil. :confused:
Thanks everyone for the kind words. ;)
I'm passed being steamed. I've also bought a 2004 X to replace the 98. I'm just going to sell the 98 when I get it fixed.
tawd77
kansas
I just put a SOHC engine in a 97, it was pretty easy. Good luck with yours.
gijoecam
Village Idiot
Trenton, MI
98 ExSport, '00 F-150
That's one of the first things my father taught me when he taught me to change the oil: Start it up and CHECK FOR LEAKS by getting on your hands and knees and looking underneath the vehicle. It saved my bacon once very early-on.... the old filter seal had stuck to the block, and the new filter seal didn't line-up. I started it up, got out of the truck, bent over and looked, and there was already a quart of oil on the floor. It doesn't take long to pump it dry!
So, lesson learned: CHECK FOR LEAKS!!!
Sorry about the bad news... Good luck on the repair!
ExplorerDMB
Moderator/Technician
Moderator Emeritus
Mechanicsville, Virginia
2004 Acura TL
easy now! :mad:
mikeh
St. Louis, MO
98 XLT SOHC V6
So who wants to come over for some beers and help me change out an engine? :p
The new X is running great. I'm not exactly excited about digging into this project. Maybe I should just part it out.
410Fortune
River Season
Staff member
Moderator
NORTH IDAHO, 7B
Callsign
FOURTEN
Hell no just replace that sucker!
Can be done in 10 hours if you are prepared and all goes smooth
R 97 Explorer exhaust blew up, really big bang Stock 1995 - 2001 Explorers 4
P Help - Is My Explorer Toast? Chain Blew Out Valve Cover Stock 1995 - 2001 Explorers 11
J 2001 Explorer XLS blew a plug.... Stock 1995 - 2001 Explorers 0
H Blew up my explorer this mornin, towed into work Stock 1995 - 2001 Explorers 5
D Blew the head gasket... Stock 1995 - 2001 Explorers 13
J Transfer case just blew Stock 1995 - 2001 Explorers 1
M egr tube blew out of intake Stock 1995 - 2001 Explorers 3
W Mounty Blew a brake line and my e-brake doesnt work. Stock 1995 - 2001 Explorers 1
G Help Radiator Blew up Stock 1995 - 2001 Explorers 4
B Overheated and blew coolant out of expansion tank Stock 1995 - 2001 Explorers 3
J Headlight Blew. WHY IS IT SO DAMN HARD TO JUST REPLACE A BULB? Stock 1995 - 2001 Explorers 40
L O/D off light flashing in 99 Ford Explorer. Stock 1995 - 2001 Explorers 6
M ECT replacement 1996 Explorer 4.0 OHV Stock 1995 - 2001 Explorers 1
N 1996 Explorer Sport 4.0L OHV Camshaft syncronizer positioning Stock 1995 - 2001 Explorers 8
K 96 Explorer fuel pump not activating Stock 1995 - 2001 Explorers 2
S Is a 1998 Explorer Limited 5.0 Full Time 4WD w/transfer case towable behind an RV with all four wheels down? Stock 1995 - 2001 Explorers 1
G My Explorer does not sit right Stock 1995 - 2001 Explorers 4
C ABS Warning Light on Explorer Stock 1995 - 2001 Explorers 0
F Switch from 5w30 to 5w20 in the Explorer - Tech Service Bulletin Stock 1995 - 2001 Explorers 35
S 1. Both Differential Oil changes plus Transfer Case, Transmission Oil Service 1998 EXPLORER LIMITED 5.0, 4 door, air suspension, AWD, Stock 1995 - 2001 Explorers 20
D 2000 Explorer 5.0 AWD Electrical Question Stock 1995 - 2001 Explorers 2
4pointslow My 2000 Explorer 4 door XLT Stock 1995 - 2001 Explorers 57
M Compatibility of 2nd Generation Explorer Limited Options with XLT Stock 1995 - 2001 Explorers 3
T 1996 explorer 4.0 ohv Stock 1995 - 2001 Explorers 4
E Can this '95 Explorer make it across the country? Stock 1995 - 2001 Explorers 25
C 99 explorer won't start Stock 1995 - 2001 Explorers 7
A 1997 Ford Explorer 4x4 Rear Differential Stock 1995 - 2001 Explorers 2
allmyEXes 1997 Explorer Key less Entry Stock 1995 - 2001 Explorers 8
I Can't program key fobs 1999 Explorer Stock 1995 - 2001 Explorers 2
W Problem with ABS on 1998 Ford explorer XLT Stock 1995 - 2001 Explorers 2
J Coolant Temperature Sensor Wiring 1999 Explorer Stock 1995 - 2001 Explorers 2
D Lost 99 Explorer keys/PATS but have a rolled 2002 Explorer w/keys and PATS Stock 1995 - 2001 Explorers 2
J Inspect Explorer for me in Arkansas Stock 1995 - 2001 Explorers 3
4 1996 Explorer XLT Stock 1995 - 2001 Explorers 13
D 99 Explorer Limited Fuel Pressure Sensor location Stock 1995 - 2001 Explorers 8
D Please help with posting a picture of your 1995 Explorer XLT Power Distribution Box Stock 1995 - 2001 Explorers 8
A no A/C 2000 5.0 Limited Explorer Stock 1995 - 2001 Explorers 15
P 1996 Explorer - what type atf Stock 1995 - 2001 Explorers 3
L 1996 Ford Explorer XLT ABS Module Failure Stock 1995 - 2001 Explorers 9
L Are all Explorer ABS modules the same 1993 to 1999 Stock 1995 - 2001 Explorers 1
M New addition, 2000 Explorer Limited Stock 1995 - 2001 Explorers 4
B No gasket between Oil pump and block? 99 Explorer 4.0 OHV. Stock 1995 - 2001 Explorers 4
D 1996 Explorer XLT: Rear Frame "issues" Stock 1995 - 2001 Explorers 26
allmyEXes 1997 Explorer rear hatch handle broken (internally) Stock 1995 - 2001 Explorers 10
D Hello, I'm in process of purchasing a 1999 Explorer XLT from our neighbor. Has a No Start crank over. Stock 1995 - 2001 Explorers 5
S 99 Ford Explorer 4.0 SOHC Help Stock 1995 - 2001 Explorers 19
D 1999 explorer 4.0l SOHC having issues Stock 1995 - 2001 Explorers 2
T 1996 Ford Explorer front diff Stock 1995 - 2001 Explorers 4
D stock 01 explorer, issue with the tach needle bouncing ???? Stock 1995 - 2001 Explorers 3
S Searching for 1996 Explorer 2WD Spindles Stock 1995 - 2001 Explorers 3
Similar threads
