I have tried relays and checked fuses, but no luck. my power windows,wipers, and interior lights do not work. Any help would be apprieceated. Thanks pony....
when you said "you tried relays"... did you test them or just replace them... test both the relay and the contacts / sockets with a meter.... most likely cause of your problem is battery saver or accessory delay.
i have check the underhood fuses too. also the relays have been replaced and i also swapped others out just to make sure.? Also what is the gem and where is it located?
