I need to tow my truck | Ford Explorer - Ford Ranger Forums - Serious Explorations
VirtualExplorer
Toronto, Canada
1991 Explorer XLT
I need to know if i need dolly's to tow my truck
I got a 91 XLT 4 by 4
Blee1099
Evil Asian
Moderator Emeritus
EF Vendor
Elkridge, MD
04 4Runner, 22 Silverado
Why do you need a tow? tranny blown, motor seized, etc? In regards to using a tow dolly it can be done but I recommend a regular trailer as supposed to a dolly.
prozachappy
SoCal
94 explorer...sportster
How far do you need to tow ? If less than a couple hundred then you'll be fine with a dolly. Just put the front up on the dolly and dissconnect your rear driveshaft. Easy to do, just 4 bolts and your done. I recommend just removing it completely and plugging your tranny with a rag or something to keep the fluid from spilling out; but you can always leave the yoke/driveshaft attached at the tranny end and just tie off the other end to the frame. Like above though if your gonna tow it more than a few hundred then you'll want to trailer it. Good luck...hope this helps
I wouldn't recommended but...you can tow a very short distance...like less than 30 miles with all four on the ground. If I remember correctly the manual says you have to keep it under 45mph the whole way and in neutral. Check your haynes it will tell you exactly what you need to do. This might only apply to the 2wd i don't remember off the top of my head.
Ford_Racing_Guy
Spencer, Wisconsin
'92 XLT & '98 XLT AWD
wouldn't be a bad idea to put the rear wheels on the dolly and lock the steering on the front wheels
VirtualExplorer
Toronto, Canada
1991 Explorer XLT
I need to tow it using a tow truck to the paint shop.
I just need to know if all four wheels need to be off of the ground
Im going about 15km to the shop
www.claudioscustoms.com
Bashman
Elite Hornet Handler
Trenton, Ontario
09 Wrangler Unlimited now
Yes, you need all 4 off the ground.
Blee1099
Evil Asian
Moderator Emeritus
EF Vendor
Elkridge, MD
You call that an emergency? Bah.. Next time read the rules of the 911 Forum before posting in there. Its only for emergency situations when your truck is broke down on the road, at home, etc..
gijoecam
Village Idiot
Trenton, MI
98 ExSport, '00 F-150
If you need to flat tow it or use a dolly on an automatic, the engine should be running in park. This will ensure that the bearings in the transmission don't get toasted. If it's a manual, you can flat tow it 'til the cows come home so long as it's in neutral.
-Joe
