I have already pressed in the ball joints in the mannor used in your link. Side note: I had rented the press from AutoZone and ended up buying one form Harbor Freight $40. The tools are Identical. I am now trying to install the Steering Knuckle back onto the axle.
The upper ball joint is smooth and is held in place by a pinch bolt. The lower joint is threaded and is held in place by a 28mm "Castle" nut. It is this "Castle" nut that I don't have the specs for. The manual Cautions: failure to follow the correct specs can result in steering problems:... The manual then points you to the spec page but only the pinch bolt is listed, the lower ball joint nut is not found...
I had e-mailed the Haynes people to inquire about the missing info...I would expect to hear back in 3-4 weeks with a messages telling me that info is not available
It is not necessary to torque the nut on the lower ball joint. Basically you just need to tighen it as tight as you can. Once it is tight you need to continue tightening the nut until the castle nut lines up with the hole allowing the cotter pin to line up. The main thing you MUST remember is to NEVER loosen or back off the nut in order to line up the hole. If you tighten the nut too much and pass the hole, the only thing to do is keep tightening it until the next slots in the nut line up.
