Foggman
- February 20, 2005
- Virginia Beach, VA
- 1994 2dr Sport
I Installed my very first locker!!! Well tonight I installed an Aussie Locker in my front end...all I have to say is WOW! what a job! Keep in mind this is the first experience I have EVER had with gears personally. Everything came apart alright until it came to the bolt that acts like a hinge on the 3rd member. To get that bolt out I had to remove my radius arm (superlift extended arm). and then while putting the actual locker in the carrier I of course had to clearance the carrier a little bit on one side but found that the small spacer that comes with the kit needs to go on the C-clip/passenger side before the locking Cam goes on on that particular side, otherwise I couldn't have gotten the cross shaft in place..I found this out after putting the whole thing together just like the directions said and having to take half of it apart again to make it work. But all in all I did the "test" laid out by Aussie Locker and everything seems to work just fine. Hopefully I will take it out on the trail this weekend or next to really "test" it out.
