MyExplorer03v8Lim
- June 20, 2016
- 2003 Explorer 4.6L
I've been chasing the P0420 code forever. Convinced I need to find the source before I swap the cats. Well boys, I think I may have found it.
A little back story, the code only seems to pop after I've been giving her wide open throttle for 5-10 seconds. Seems to be related to heat or stress.
I was worried I'd been dripping coolant into the combustion chambers from an internal intake gasket blowout. Maybe not.
After much looking around I embarrassingly finally found a pretty glaring issue. There's a snapped stud on the low side of port 4 @ the exhaust manifold (right hand side, back of engine). Also, the flange where it bolts to the cat is snapped on the manifold side.
You can see pics here:
http://imgur.com/aRf65jI - broken flange @ cat pipe. Broken on manifold side.
http://imgur.com/070U2z2 - broken stud @ cylinder 4.
So my question to you guys is what should I expect to pay for a shop to do this job. And follow up question, should I try to do it myself. And if I'm doing one, should I do both?
