Neitron
- January 6, 2018
- Kansas City, MO
- 13 PIU
In the process of trying to get the horn working, I shorted something and now the car wont do anything, almost.
I thought I was about to make the horn sound, but instead I got a spark and the wire was welded to the frame. followed by everything going off and no activity when i turn the key to any of the positions.
What works: the power locks, the radio / no display, the lights inside and out, power seats, and power port.
What doesn't: any action from inserting or turning the key, displays both drivers and middle, HVAC (no activity).
I have pulled the neg off battery (nothing new), checked all fuses under hood (all good), and fuse22 horn (and good).
I believe I had the lead on the purple/green wire coming out of the BCM, but pulled it out before I thought about confirming the placement, when the wire shorted and "I lost everything"
I'm looking for any suggestions before I dive under the dash to check fuses in 16 degree car.
Note: I have FORscan but only used it once and saved the information to tablet. Now i'm not sure when i connect it if I am looking at the current car settings or if it is reverting back to the saved file. So, I do have FORscan as a tool if it will help in diagnoses.
